02-21-2017 11:29 PM - edited 03-17-2019 09:36 AM
i have a probleme with my uc500
we have a contract with belgacom for 20 numbers public phone.
we have connect the "box" off belgacom on 2 port bri 0/1/0 and bri 0/1/1.
the problem is :
- all call in icoming is impossible. when i call (with my smartphone) on ons numbers belgacom, the comunication is close directly
informations :
-all téképhone cisco are ok
-all call in outgoing are ok
-all call in intra are ok
i send my config.
Thx
02-22-2017 01:06 AM
So you mean to say all outgoing calls work but the incoming calls are failing. Do you see the incoming calls hitting the gateway if you enable any debugs like "debug ccsip messages" and "debug voice ccapi inout". If the incoming call hits this UC500 then you should capture the debugs and post here with the calling and called party details, if the call does not even reach the UC500 then you should speak with your Telco/Provider.
Manish
02-22-2017 01:32 AM
it's exacly.
all outgoing calls work and all incoming calls are faling.
i have launch a debug. my call come on the uc500 but i think the call is not redirect on the ip-phone.
the problem come on the translation route on bri interfaces ?
thx
02-22-2017 01:50 AM
Could you please provide debug output (isdn and ccapi) with calling and called party info
02-22-2017 03:13 AM
it's the isdn debug when i call a number on my uc 500.
th call come on my uc but after...
*Feb 22 10:55:50.487: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x71
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2181, '488299206'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '71469850'
High Layer Compat i = 0x9181
*Feb 22 10:55:50.495: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xF1
Channel ID i = 0x89
Exclusive, B1
*Feb 22 10:55:50.519: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xF1
Cause i = 0x8090 - Normal call clearing
*Feb 22 10:55:50.711: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x71
*Feb 22 10:55:50.715: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xF1
