isdn incorrect calling number display?
samhopealpha
Level 2
Level 2
Hi Everybody,
I tried to make a call from CUCM's IP Phone to my mobile phone through the VG's T1
I have started the "debug isdn q931", and see
Calling Party Number is 3555 7000,
Called Party Number is 6699 4488 (my mobile)
Howevery, my mobile shows the Caller Display is "3555 7100" , I suppose it should be "35557000" ....
What else could make this happen? is it because the Telecom has wrongly converted my Calling Number? or there is any conflict in CUCM?
Here is the result of debug q931
ISDN Se0/0/1:23 Q931: Tx -> SETUP pd = 8 callref = 0x000B
    Bearer Capability i = 0x8090A2
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Cannel ID i = 0xA98397
        Exclusive, Channel 23
    Calling Party Number i = 0x0081, '35557000'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '66994488'
ISDN Se0/0/1:23 Q931: Rx <- SETUP_ACK pd = 8 callref = 0x800B
    Channel ID i = 0xA98397
ISDN Se0/0/1:23 Q931: Rx <- CALL_PROC pd = 8 callref = 0x800B
    Progress Ind i = 0x8288 - In-band info or appropriate now available
ISDN Se0/0/1:23 Q931: Rx <- ALERTING pd = 8 callref = 0x800B
    Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
ISDN Se0/0/1:23 Q931: Rx <- CONNECT pd = 8 callref = 0x800B
ISDN Se0/0/1:23 Q931: Tx -> CONNECT_ACK pd = 8 callref = 0x000B
Thanks in advance
Sam
Jaime Valencia
This is the info you're sending:
If you see something else on the called phone it's because someone in the middle is overwriting that info.
Get in touch with Telco for this matter, if those are DIDs, do you own 7000??? Telcos do this if you do not own the DID and use the main DID number of what you do own.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks for the reply, I think  I have to contact with Telco on tomorrow...
Let see what's happening
acampbell
Sam,
Is 3555 7100 your ISDN service billing number ?
Here in the UK we have to pay the TELCO to allow
the DDInumber to go out instead of the billing number.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
