Highlighted
Beginner
isdn is unable to backhaul to ccm manager
"isdn bind-l3 ccm-manager service mgcp" command is automatically missing from the isdn interface and all the phones are going down. This has been happening intermittently at several locations. When I re-issue the command, it works fine.
Can you please suggest the solution?
Many Thanks.
5 REPLIES 5
Highlighted
Hi prasad.manju,
can you please provide the config of your router as well as the sh ver output?
Cheers,
Highlighted
hostname router
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret xxxxx
no aaa new-model
resource policy
clock timezone gmt 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
tdm clock bri-auto
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
ip cef
no ip domain lookup
ip sla monitor responder
isdn switch-type basic-net3
voice rtp send-recv
voice service voip
modem passthrough nse codec g711ulaw
application
global
service alternate default
interface FastEthernet0/0
description IP Address for CCM Gateway
ip address E.F.G.H x.x.x.x
speed 100
full-duplex
interface BRI0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/1
no ip address
isdn static-tei 0
ip route 0.0.0.0 0.0.0.0 A.B.C.D
no ip http server
control-plane
voice-port 0/0
compand-type a-law
cptone GB
voice-port 0/1
compand-type a-law
cptone GB
ccm-manager fallback-mgcp
ccm-manager redundant-host W.X.Y.Z
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server P.Q.R.S P.Q.R.L
ccm-manager config
mgcp
mgcp call-agent W.X.Y.Z 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 91 pots
destination-pattern 9T
direct-inward-dial
port 0/0
dial-peer voice 92 pots
direct-inward-dial
port 0/1
call-manager-fallback
max-conferences 4 gain -6
limit-dn 7940 1
limit-dn 7960 2
timeouts interdigit 5
ip source-address E.F.G.H port 2000 strict-match
max-ephones 24
max-dn 24
transfer-pattern 1234....
time-format 24
date-format dd-mm-yy
router#sh ver
Cisco IOS Software, C1700 Software (C1700-SV8Y7-M), Version 12.4(5a), RELEASE SO
FTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 14-Jan-06 04:18 by alnguyen
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
router uptime is 2 weeks, 3 days, 4 hours, 31 minutes
System restarted at 09:17:04 BST Mon May 7 2007
System image file is "flash:c1700-sv8y7-mz.124-5a.bin"
Cisco 1760 (MPC860P) processor (revision 0x600) with 116944K/14128K bytes of mem
ory.
Processor board ID FOC094000GV (2337081928), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
2 ISDN Basic Rate interfaces
4 Voice NT or TE BRI interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Highlighted
If MGCP falls back to H323 the config is changed and this command is deleted automatically.
This is expected behaviour if the registration failes - you have "service alternate default" configured.
I had once an issue with this when the WAN link flapped.
-> check if you lose registration with CCM
-> check if router goes from MGCP to H323
-> check WAN connectivity (flaps?)
Possible that you have a SW issue when the gateway goes back from H323 to MGCP...
It's of course also possible that you have an IOS with some personality / bugs.
Cheers,
Martin
Highlighted
To do MGCP BRI Backhaul, you need an IOS T Train, (12.4T), to make it work fine.
Your config has no problem at all.
cheers
jp
Highlighted
I had a similar issue with my config rewriting on its own for supporting a PRI of less than 24 channels. A temporary workaround that was given to me was once the gateway is up and registered remove the "ccm-manager config" command once you reconfig the idsn backhaul on your BRI. This is something i used because the CallManager was overwriting parts of my config rather than deleting the line entirely. Hope it helps till you find something better.
Content for Community-Ad
