ISdn Issue
tkavithas87
Following is the status of isdn interface.
Inhwa-HQ-UC560#show interfaces serial 0/3/0:15
Serial0/3/0:15 is down, line protocol is down
  Hardware is DSX1
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 02:52:07, output never, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     498425 packets input, 2249088 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     25 runts, 0 giants, 0 throttles
     78 input errors, 78 CRC, 0 frame, 0 overrun, 0 ignored, 4 abort
     498551 packets output, 2233882 bytes, 0 underruns
     0 unknown protocol drops
     4 carrier transitions
  Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
This is down.what could be the cause?
thanks
kavi
It look like a physical problem...maybe the cable is damaged or at the other side the T1 is down.
Please rate all useful posts
_____________________________
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
The problem was the isdn cable was disconnected.
thanks
