ISDN: Recovery on timer expiry
appserv
We have a remote site using H323 on a 1861. The IOS is 12.4(15)XY2. We have the following problem, when we receive a call from a cell network we get the Recovery on Timer Expiry error message. This has only started to happen since we told our Telco to enable Caller ID on the BRI.
Failed Call:
000351: Jun 4 01:24:36.291: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x18
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Date/Time i = 0x0806040D18
Date (yr-mm-dd) = 08-06-04
Time (hr:mnt:sec) = 13:24:52
Signal i = 0x40 - Alerting on - pattern 0
Calling Party Number i = 0x2183, '212484869'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '4070760'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
000352: Jun 4 01:24:36.303: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x98
Channel ID i = 0x89
Exclusive, B1
000353: Jun 4 01:24:46.655: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x18
Cause i = 0x82E6333130 - Recovery on timer expiry
000354: Jun 4 01:24:46.659: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x98
Good Call:
000355: Jun 4 01:25:17.700: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x19
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Date/Time i = 0x0806040D19
Time (hr:mnt:sec) = 13:25:52
Calling Party Number i = 0x2181, '93631830'
000356: Jun 4 01:25:17.712: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x99
Channel ID i = 0x89
Exclusive, B1
000357: Jun 4 01:25:17.792: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x99
Progress Ind i = 0x8188 - In-band info or appropriate now available
000358: Jun 4 01:25:18.576: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x99
Channel ID i = 0x89
Exclusive, B1
000359: Jun 4 01:25:18.664: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x19
000360: Jun 4 01:25:21.136: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x19
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
000361: Jun 4 01:25:21.152: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x99
000362: Jun 4 01:25:21.428: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x19
Can anyone explain what could be happening?
13 Replies 13
bwilmoth
Level 5
Level 5
This situation can be resolved by increasing the value of timer T310. This can be done on the Cisco IOS gateway.
IOS configuration is achieved through the following interface command
Router(config-if)#isdn t310
By default what is this value? And what is the best practice for this value? Should I increse\decrease it?
paolo bevilacqua
This happens when the outgoing voip leg gets no response. See 10 seconda have passed without further acknowledgment after CALL_PROC, so rightly the nextowkr disconnects.
Check you DP config, why is the first call treated differently than the second? Apparently, only the calling number is different.
Thanks for the responses.
This is a copy of how my dial peers are setup. This config has worked for us in the past using 2801 routers.
dial-peer voice 1 pots
tone ringback alert-no-PI
preference 1
destination-pattern 1T
progress_ind alert enable 8
direct-inward-dial
port 0/1/0
dial-peer voice 100 voip
preference 1
destination-pattern 5510.
progress_ind setup enable 0
voice-class codec 10
voice-class h323 1
session target ipv4:172.29.2.97
incoming called-number 1T
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 voip
preference 2
voice-class h323 1
session target ipv4:172.29.2.96
no vad
Hi, are you doing some translation somewhere ? Because the called number from you trace does not match "destination-pattern" in the voip DP.
You can also enable "debug cch323" and see what happens, if anything, with the voip call when it fails.
Hi Paolo,
Yes we are doing translations - I cannot test right now as I needed to get the site working ASAP and have told the telco to remove caller id. Waiting on a spare 1861 to be delivered.
thanks.
Replacing hardware will not change anything.
You have either a subtle configuration issue, or a bug in the new XY IOS.
Aware of that- new hardware is to setup a test lab to troubleshoot this further.
Any other thoughts much appreciated.
pijssel
Hi guys,
Currently I'm having the same issue. As a customer is calling from an Amsterdam site over an ISDN PRI line to a destination in London. Sometimes the call gets connected, and sometimes the get the "Cause i = 0x82E6 - Recovery on timer expiry" error.
I guess this has something to do with the called party being busy, and the busy signal not being forwarded correctly to the Voice Gateway in Amsterdam. I allready tried adjusting the T310 timer, but without any result.
Is there an other way to force this signal, maybe by setting a Progress Indicator?
Thanks in advance.
Paul van den IJssel
Digacom
The Netherlands
debug isdn q931 output:
Jul 3 15:39:54: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x5590
Standard = CCITT
Channel ID i = 0xA9838E
Exclusive, Channel 14
Calling Party Number i = 0x00A1, '301'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '004420796XXXXX'
Jul 3 15:39:54: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0xD590
Cause i = 0x82E46C - Invalid information element contents
Call State i = 0x01
Jul 3 15:39:54: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xD590
Jul 3 15:40:01: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xD590
Jul 3 15:40:19: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xD590
Jul 3 15:40:19: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Pos
tpone sending RELEASE for callid 0xD511
Jul 3 15:40:22: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x5590
Jul 3 15:40:22: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xD5
90
Hi, I would begin eliminating the first error and going from there:
Which switch-type is configured? Have you configured a channel selection "exclusive" ? Can you sent the correct main number or nothing at all, as calling ?
For some reason the CO is complaining.
The switch type is Primary net 5, you can also look this up in the config which I attached. I'm not quite sure what you mean with the channel selection "exclusive".
I am unable to send the correct main number, that is why I've set the CLID to restricted on the CM.
Do you have any suggestions?
Thanks in advance.
Best regards,
Paul van den IJssel
pijssel
VG config
Hi, the first STATUS message "may" still be related to the calling number, however is not the cause of the problem.
I think that there is nothing that you can do. Telco sends CALL_PROC, after that telco sends disconnect. The timer expirya is occurring on the called party, not your. Try asking them if they have a cisco with configuration problem :)
