ism 8.6.4 stuck in user mode
Marc El Achkar
I have a cme with ism cue installed,everytime i session to my ism0/0, it seems as if i am in stuck in user mode, i can't go in offline mode nor change anything in the configuration of the ism, i cant go in the enable mode.
the web pager of the gui opens up but can't login also, i keep getting:
System is not initialized. Only Administrator logins are allowed.
9 Replies 9
paolo bevilacqua
Log in with CLI and complete wizard.
the thing is when i loging with cli , im not getting any wizard to complete.
In CLI check administrator credentials, login in GUI with that, you will presented the wizard.
ou
as you can see in the above picture im not having any exec command to do the wizard or any config...
You can re-install CUE software, or check what happens at boot (service module reset).
Note: when working with CLI devices, use text copy and paste, not screenshots.
Paolo 1st thx for your help,
at the reset i get the following :
192.168.200.10#service-module isM 0/0 reset
Use reset only to recover from shutdown or failed state
Warning: May lose data on the the NVRAM, nonvolatile file system or unsaved configuration!
Do you want to reset?[confirm]
Trying to reload Service Module ISM0/0.
192.168.200.10#ser
192.168.200.10#service-module isM 0/0 ses
192.168.200.10#service-module isM 0/0 session
Trying 192.168.200.10, 2131 ... Open
DDR Memory 0512 MB detected
Genuine Intel(R) processor              1.06GHz
BIOS ISM 2.6,  BIOS Build date: 10/16/2009
System now booting...
Authenticating boot loader....
Secondary Boot Loader authenticated - booting....
Please enter '***' to change boot configuration:
Detect and Initialize network device
Backup current platform configurations....
SRE step 1 - SM registration...
Finding (hd0,3)/296e03bc-3236-4a68-a178-688e56400a1e, failed
Local install not supported
Response - no installation needed (len: 422)
SRE Installation Not Needed
Restoring orignial configuration...
Updating flash with bootloader configuration.
Please wait .................. done.
Loading disk:/bzImage ... Verifying ... done.
Starting Kernel.
Platform: ism
  sd 0:0:0:0: [sda] Assuming drive cache: write through
Verifying application level programs
Application level programs verification OK!
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
reiser root fs ...
Reiserfs super block in block 16 on 0x801 of format 3.6 with standard journal
Blocks (total/free): 1002928/905703 by 4096 bytes
Filesystem is NOT clean
Filesystem seems mounted read-only. Skipping journal replay.
Checking internal tree..finished
FILESYSTEM CLEAN
Remounting the root filesystem read-write...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
vm.min_free_kbytes = 8192
                Welcome to Cisco Service Engine
Setting the system time from hardware clock
********** rc.aesop ****************
Populating resource values from /etc/ism_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/ism_rsrc_file
Processing manifests . . . . . . . . . . . . complete
==> Management interface is eth0
Serial Number: FOC16383CYB
INIT: Entering runlevel: 2
********** rc.post_install ****************
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
==> Starting CDP
STARTED: ntp_startup.sh
STARTED: LDAP_startup.sh
STARTED: SQL_startup.sh
STARTED: dwnldr_startup.sh
STARTED: HTTP_startup.sh
STARTED: probe
STARTED: fndn_udins_wrapper
STARTED: superthread_startup.sh
STARTED: /usr/wfavvid/run-wfengine.sh
STARTED: /usr/bin/launch_ums.sh
Waiting 45 ...
and then the ism gets online with the above limitations.
Seems like a corrupted installation that you will have to do again.
ahhh..
it came like this directly from cisco, it was ordered with the ism in it..
thank you for your help:)
All the SMs I've installed sofar needed to have software installed. Maybe now they come with this placeholder software.
Thank you for the nice rating and good luck|
