ISR 4321 with CUBE
John_Webster
Can someone verify if I need CUCM with CUBE or can CUBE stand alone ?
George Sotiropoulos
Hello John,
Amongst others, you need to consider the sizing, more specifically you will need share with us the number of users your Voice Gateway will need to serve.
You can find a lot of posts in the Community with comparison between CUCM and CME (stand-alone router).
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Jaime Valencia
Please do not create duplicate posts in the forum
https://community.cisco.com/t5/unified-communications/isr-4321-k9-with-cube/m-p/4054606
java
if this helps, please rate
Vinod Dahiya
Hi John,
You need a CUCM with CUBE or a CME to register your endpoints. CUBE will be used to configure your ITSP/ Service Provider for SIP channels.
CUCM--> SIP Trunk--> CUBE--> ITSP
Vinod Dahiya
Together we can solve, Let's do it together.
