in my case I also want to go with CUE virtual in KVM.
I do have a UCS-E module in my router with 100 GB of space (100 GB, mSATA SSD for NCE NIM)
I raised a TAC case to check if I can utilize this storage for my KVM however I am told it can't be used. They mentioned below are supported storage:
Supported storage devices for ISR4k will be
SSD-MSATA-200G (on motherboard)
Yes
Yes
Yes
3.13.1
200 GB, mSATA Solid State Disk (for ISR motherboard slot)
NIM-SSD
Yes
Yes
Yes
Yes
Yes
3.10
NIM Carrier Card for up to 2 SSD Drives
SSD-SATA-200G
Yes
Yes
Yes
Yes
Yes
3.10
200 GB, SATA Solid State Disk for NIM-SSD
SSD-SATA-400G
Yes
Yes
Yes
Yes
Yes
400 GB, SATA Solid State Disk for NIM-SSD
SSD-SATA-800G
Yes
Yes
Yes
Yes
Yes
800 GB, SATA Solid State Disk for NIM-SSD
Adaptors
SM-X-NIM-ADPTR
Y
Y
Y
3.14
SM-X Adaptor for one NIM module
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#storage
regards,
Anil Sharma
