07-11-2018 08:52 AM - edited 03-17-2019 01:10 PM
Any support is appreciated.
Configured E1 in IST 4331. bout voice-port is not recognized E1 is not sowing in voice port summary
Configuration
card type e1 0 1
isdn switch-type primary-net5
controller E1 0/1/0
framing no-crc4
pri-group timeslots 1-30
no sh
interface Serial0/1/0:15
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no sh
voice-card 0/1
dsp services dspfarm
encapsulation hdlc
no sh
no network-clock synchronization participate 0
when i configure voiceport
voice-port 0/1/0:15
% Invalid input detected at '^' marker.
123-VG1#sh inventory
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V04, SN: XXXX
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V03, SN: XXXXX
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-1CE1T1-PRI - T1/E1 Serial Module"
PID: NIM-1CE1T1-PRI , VID: V04, SN: XXXX
NAME: "subslot 0/1 db module 0", DESCR: "PVDM4-32 Voice DSP Module"
PID: PVDM4-32 , VID: V02, SN: XXXXXX
NAME: "NIM subslot 0/2", DESCR: "NIM-2FXO Voice Analog Module"
PID: NIM-2FXO , VID: V02, SN: XXXXXX
NAME: "PVDM subslot 0/4", DESCR: "PVDM4-32 Voice DSP Module"
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE , VID: V01, SN: XXXXXX
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331/K9 , VID: V04, SN: XXXXXX
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
123-VG1#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/2/0 -- fxo-ls down down idle on-hook y
0/2/1 -- fxo-ls down down idle on-hook y
PWR FAILOVER PORT PSTN FAILOVER PORT
123-VG1#show controllers E1
E1 0/1/0 is down.
Applique type is Channelized E1 - balanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Framing is no-crc4, Line Code is HDB3, Clock Source is Line Primary.
International Bit: 1, National Bits: 11111
Data in current interval (587 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 587 Unavail Secs
Total Data (last 4 15 minute intervals):
949 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 3600 Unavail Secs
The Physical E1 Cable is not connected. I am in a stage make the Gateway ready so it will be plug and play once E1 connection available
Solved! Go to Solution.
07-11-2018 08:58 AM
NIM-1CE1T1-PRI >> this is a channelized card.
Add "voice-dsp" to the pri-group command under the controller. That should fix it.
controller E1 0/1/0
pri-group timeslots 1-30 voice-dsp
07-11-2018 08:58 AM
controller E1 0/1/0
07-11-2018 09:07 AM
