08-22-2016 03:11 PM - edited 03-17-2019 07:54 AM
A few questions.
1. Are their actual SRST license files that needed to be uploaded to a 2800 series ISR? Or is this on the "honor" system
2. If license files requried on ISR 2800 series AND you have to re-ip the gateways, do you have to have new SRST license files generated/applied by Cisco.
3. ISR 4300 - Will there be actual SRST liense files that need to be uploaded? Or will it be on "honor" system.
thank you in advance.
Solved! Go to Solution.
08-22-2016 04:41 PM
ISR G1 do not require license. The product family 18XX, 28XX, and 38XX remains unchanged and will not adopt the licensing, packaging and universal image concept which is outlined for the ISRG2 family .
changing ip will not make difference
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd804e773d.html
Sames goes to ISR G3 4XXX its RTU honor based.
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
08-22-2016 05:19 PM
SRST is Right To Use (RTU) - you don't need to register any PAK or upload any specific license files for SRST. However before you can configure that you need uc9 technology pack and accept the EULA from CLI.
Ref: http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#pgfId-1204791
Ref for ISR 4K: http://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_0101.html#task_F3FCF5F121E64998AB888E13E1BA1858
The Cisco ISR G2 comes with a 60-day evaluation license. After 60 days, the license changes to “right to use”. The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Note CME-SRST RTU license is introduced in Cisco IOS release 15.1(3)T and higher.
08-22-2016 04:41 PM
08-22-2016 05:19 PM
08-22-2016 05:20 PM
Edit: SRST is Right To Use (RTU) - you don't need to register any PAK.
It was typo I meant you dont need to register any PAKs (same as before)
08-22-2016 08:11 PM
[+5] to Terry and Nadeem.
these licenses would show as below under Evaluation period of 60 days. the snapshot captured before July 24.
Feature: cme-srst Version: 1.0
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 3 weeks 3 days
Period used: 5 weeks 0 day
Transition date: Jul 24 2016 16:29:20
License Count: 20/0 (In-use/Violation)
After the evaluation period gets expired , status would change as below. The snapshot captured after July 24,2016
License Type: RightToUse
regds,
aman
08-22-2016 08:13 PM
+5 Aman my friend hope you are doing good.
08-23-2016 08:20 AM
Thanks to all, Much appreciated
