ISR4331-V/K9 Add Voicemail License
omar Alqadi
kindly,  below is configuration for CME ISR4331-V/K , i faced in this configuration no i have voice mail License ,can you guide me how select Voice mail Licenses in this module.
ISR4331-V/K9 Cisco ISR 4331 UC Bundle, PVDM4-32, UC License, CUBEE10 1
CON-SNT-ISR4331V SNTC-8X5XNBD Cisco ISR 4331 UC Bundle, PVDM4-32, UC L 1
MEM-FLSH-4U8G 4G to 8G eUSB Flash Memory Upgrade for Cisco ISR 4300 1
FL-CME-SRST-5 SRST-5 Seat License (CME uses CUCME Phone License ONLY) 2
PVDM4-32 32-channel DSP module 1
MEM-43-4G 4G DRAM (1 x 4G) for Cisco ISR 4300 1
FL-CUBEE-5 Unified Border Element Enterprise License - 5 sessions 2
FL-SRST Cisco Survivable Remote Site Telephony (SRST) License 1
PWR-4330-AC AC Power Supply for Cisco ISR 4330 1
CAB-ACU AC Power Cord (UK), C13, BS 1363, 2.5m 1
SL-4330-UC-K9 Unified Communication License for Cisco ISR 4330 Series 1
SISR4300UK9-316S Cisco ISR 4300 Series IOS XE Universal 1
SL-4330-IPB-K9 IP Base License for Cisco ISR 4330 Series 1
NIM-4FXO 4-port Network Interface Module - FXO (Universal) 1
SM-S-BLANK Removable faceplate for SM slot on Cisco 2900,3900,4400 ISR 1
NETWORK-PNP-LIC Network Plug-n-Play License for zero-touch device deployment 1
FL-UCSE-VS6-FND UCS E-Series VMware ESXi 6 Foundation (with vCenter) License 1
CON-ECMU-FLUCSEVF SWSS UPGRADES UCS E-Series VMware ESXi 6 Foundation (with vC 1
E100-SD-2G 2 GB SD Card for UCS-EN 1
E100N-SSD-50G 50 GB, mSATA SSD for NCE NIM 1
UCS-EN140N-M2/K9 UCS E-Series NCE, 4-core, 8GB RAM, 1 SSD, NIM 1
SW-UCSE-VM-6.0-K9 VMware Vsphere Hypervisor (ESXi) v6.0 software for UCS E 1
Omar
Hi Omar,
Attached a recent BoM I created for one of my customers.
I removed the list price column, but with specified part numbers you can ask for e quote to your Cisco salse representative.
Let me know if it helps.
Carlo
Please rate all helpful posts "The more you help the more you learn"
10 Replies 10
Chris Deren
For ISR4K onboard voicemail you will need Unity Connection running on UCS E-blade, i.e SR-910 along with CUC licenses as there is no built in voicemail solution into the router like CME:
here is list of compatibility:
http://docwiki.cisco.com/wiki/Cisco_Unity_Connection_on_UCSE
and data sheet for E-blade:
https://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/data_sheet_c78-553913.html
R0g22
It depends upon what sort of a deployment. If you are trying to use CME and for a small to medium office/site, you might need Unity Express that can run on top ESXi on the UCS-E module that you have highlighted. Regarding the licenses, post 9.0.3 version, you don't need to buy port licenses. They are already there and set to platform maximum. You would need to worry about MBX and IVR sessions if you plan to use advanced IVR features like fax/email, database etc.
thank you  for reply.
i selected of configuration for L-CME-CUE as below Table:
is this configuration need more specification on configuration of ISR4331-V/K9:
Part Number Part Description Quantity
L-CME-CUE Communication Manager Express (CME) - E-Delivery-Top Level 1
CME-UL Cisco Communication Manager Express (CME) - 1 User License 4
CON-ECMU-CMEULCTG SWSS UPGRADES Cisco Communication Manager Express (CME 4
CUE-VM Cisco Unity Express (CUE) - 1 VMail License (E-Delivery RTU) 10
CON-ECMU-CUEGTVMV SWSS UPGRADES Cisco Unity Express (CUE) - 1 VMail Lice 10
CUE-IVR Cisco Unity Express (CUE) - 1 IVR License (E-Delivery RTU) 2
CON-ECMU-CUEIVRTB SWSS UPGRADES Cisco Unity Express (CUE) - 1 IVR Licens 2
omar
Looks good to me. You can let go of CUE-IVR if you only plan to use CUE for basic AA only functionality. Remember, out of the pool of available ports which like I said will be 20 or maximum for platform, every IVR session will consume 1 port which would leave less ports available to take VM, AA, user VM access calls.
Thank you for your information
I'm confused Now ,
I'm  looking for Cisco Call manager express supported  the following :
1- 4 analog lines (PSTN )
2- 10 IP-Phones (basic models)
3- and necessary license for VM ,IVR,trunk ,EXT, etc.
Can you Please  help me to do configuration for BOQ .
I would suggest contacting a UC specialized Cisco Partner in your area. They can run a no cost BOM for you.
Thank you
in ISR4331-V/K9  i think  this item UCS-EN140N-M2/K9  Provide unity
but what is the next step for  application and   licenses can a add to system.
regards
Yes that is the correct PID. These are meant for ISR-4k's only and you can have upto 2 of these modules on the same ISR4331 chassis.
Now, you would need to install ESXi through CIMC on this module and then run CUE or CUC as a virtual machine.
The following links should be helpful -
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel9_0/install/cue_install_book/cue_virtual_support_for_esxi.html
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/3-1-1/gs/guide/b_Getting_Started_Guide/b_3_x_Getting_Started_Guide_chapter_011.html
Hi Omar,
Carlo
Thank you carlo , yes this what I need .
Thank  all for support and replys
