08-03-2020 02:39 AM
Hi Community.
Have a problem with SCCP start.
Trying to setup it with https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeconf.html
But have a problem with TCP_CONN_ERROR for Conference application.
What am i missing?
Thank you
---cut here---
moscow_isr4331#show sccp all
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0/0
IPv4 Address: 10.2.0.253
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.2.0.253, Port Number: 2000
Priority: 1, Version: 6.0, Identifier: 1
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 32, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
SCCP Application Service(s) Statistics:
Profile Identifier: 1, Service Type: Conferencing
Backlog Q Depth: 0 Socket -1 Appl 7F259C8D27F0
TCP packets rx 0, tx 0
Unsupported pkts rx 0, Unrecognized pkts rx 0
Register tx 0, successful 0, rejected 0, failed 0
Unregister tx 0, successful 0
KeepAlive tx 0, successful 0, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
StartMediaTransmission rx 0, successful 0, failed 0
StopMediaTransmission rx 0, successful 0, failed 0
PortReq rx 0
PortRes tx 0, successful 0, failed 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
QosTeardown rx 0, send 0, recv 0, sendrecv 0
QosResvNotify tx 0, send 0, recv 0, sendrecv 0
QosErrorNotify tx 0, send 0, recv 0, sendrecv 0
err0 0, err1 0, err2 0, err3 0, err4 0, err5 0,
err6 0, err7 0, err8 0, err9 0, err10 0, err11 0,
err12 0
QosModify rx 0, send 0, recv 0, sendrecv 0
UpdateDscp rx 0
OpenMultiMediaReceiveChannel rx 0, successful 0, failed 0
CloseMultiReceiveChannel rx 0, successful 0, failed 0
StartMultiMediaTransmission rx 0, successful 0, failed 0
AddParticipant rx 0, successful 0, failed 0
ChangeParticipant rx 0, successful 0, failed 0
DropParticipant rx 0, successful 0, failed 0
MiscellaneousCommand rx 0, tx 0
FlowControlCommand rx 0, tx 0
Reset rx 0, successful 0, failed 0
MediaStreamingFailure rx 0
MediaStreamingFailure tx 0
Switchover 0, Switchback 0
CCM Group Identifier: 1
Description: None
Binded Interface: GigabitEthernet0/0/0
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated Profile: 1, Registration Name: CME-CONF
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: IMMEDIATE, Switchback Method: IMMEDIATE
Switchback Interval: 15 sec, Switchback Timeout: 0 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total Video Conferencing Sessions: 0, Connections: 0
Total Video Transcoding Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
Statistic Count
Send queue enqueue error 0
Socket send error 0
Msgs discarded upon error 0
moscow_isr4331#
Solved! Go to Solution.
08-10-2020 11:37 PM
After delete line
create cnf-files version-stamp Jan 01 2002 00:00:00
from config file, i`ve uploaded it to ISR and reboot.
After that port 2000 became avalable
08-03-2020 02:54 AM - edited 08-03-2020 02:57 AM
Multiple things you check,
On ISR Conference, make sure the codec is mentioned.
What is the maximum conference participants set? There may be exceeding of participants.
08-03-2020 03:58 AM
08-03-2020 08:48 AM
08-05-2020 02:05 AM
port 2000 is not available.
Is somebody have any iadeas?
moscow_isr4331#sh ip ports all
Proto Local Address Foreign Address State PID/Program Name
TCB Local Address Foreign Address (state)
tcp 10.1.0.9:22 172.16.254.254:64687 ESTAB 236/[IOS]SSH Process
tcp *:1720 *:* LISTEN 648/[IOS]CCH323_CT
tcp *:5060 *:* LISTEN 631/[IOS]CCSIP_TCP_SOCKET
udp 10.2.0.253:5060 10.2.0.68:5060 630/[IOS]CCSIP_UDP_SOCKET
udp 10.2.0.253:123 *:* 3/[IOS]OVLD SPA Background process
udp :::123 :::* 3/[IOS]OVLD SPA Background process
udp 10.2.0.253:67 10.2.0.66:68 624/[IOS]DHCPD Receive
udp 10.2.0.253:2517 0.0.0.0:0 648/[IOS]CCH323_CT
udp 10.1.0.9:161 172.16.254.12:34133 651/[IOS]IP SNMP
udp 10.2.0.253:162 *:* 651/[IOS]IP SNMP
udp 10.2.0.253:62340 *:* 651/[IOS]IP SNMP
udp :::161 :::* 654/[IOS]IP SNMPV6
udp :::162 :::* 654/[IOS]IP SNMPV6
udp :::53525 :::* 654/[IOS]IP SNMPV6
udp 10.2.0.253:58903 62.141.108.238:5060 630/[IOS]CCSIP_UDP_SOCKET
udp 10.2.0.253:64598 172.29.1.23:5060 630/[IOS]CCSIP_UDP_SOCKET
udp 10.2.0.253:60643 10.0.17.24:5060 630/[IOS]CCSIP_UDP_SOCKET
udp *:64009 10.2.0.66:5060 630/[IOS]CCSIP_UDP_SOCKET
udp *:63513 10.2.0.70:5060 630/[IOS]CCSIP_UDP_SOCKET
udp *:64728 10.2.0.65:5060 630/[IOS]CCSIP_UDP_SOCKET
udp *:53696 10.2.0.67:5060 630/[IOS]CCSIP_UDP_SOCKET
moscow_isr4331#
08-10-2020 11:37 PM
After delete line
04-11-2023 09:30 AM
Hello Anton,
that post is quite old, but could you explain what you did? Have a quite similar issue here.
Thanks.
