11-10-2016 08:31 PM - edited 03-17-2019 08:39 AM
My client has cisco ISR4351 gateway with a 4th generation fxs card - NIM-4FXS.
but seems ISR4351 getaway is not supported on callmanager 10. Minimum version should be 10.5.
voice gateway works with ccm over h323. But not this new fxs module. I was trying to use stcapp for FXS port.
question:
Without upgrading CCM to minimum version 10.5, are there any other alternative ways to get this NIM-4FXS card on ISR 4351 working with CCM10.0?
Thanks in advance!
Eric
Solved! Go to Solution.
11-10-2016 11:37 PM
Hi Eric,
you can try CISCO BUG search tool any time to search for BUGs
https://bst.cloudapps.cisco.com/bugsearch/
Unfortunately the crux of matter is you would have to upgrade to 10.5 as there is no COP file available for same.
JB
11-10-2016 09:28 PM
Hi Eric,
There is a BUG which plagues the 4K series for stcapp, check below.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu26939/?reffering_site=dumpcr
JB
11-10-2016 09:36 PM
there is another enhancement open for this
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo65091
JB
11-10-2016 09:49 PM
Thanks Jitender,
Yes, there are some defects on ISR 4000 series, quite annoyed.
But my problem is ISR4351 is not shown on the gateway dropdown list once you click add new gateway on callmanager 10.0. I know I could upgrade the whole platform to 10.5 in order to have 4351 gateway in th dropdown menu. However, it is sort of overkill to fund up for ccm upgrade to connect couples of fax line via this new FXS card.
I am hoping that there is a sort of cop patch file, which I could just patched it to call manager, just like what we normally do to get latest model phone installed on bit obsolete version of CCM.
Cheers, Eric
11-10-2016 10:04 PM
Hi Eric,
here is the BUG https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo85914/?reffering_site=dumpcr
JB
11-10-2016 10:24 PM
Hi Jitender,
The enhancement track appears as tomcat error when I attempt to open it.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo85914/CSCuz40162
Does it work for you?
Thanks, Eric
11-10-2016 10:29 PM
Hi Eric,
this is what it says
11-10-2016 11:02 PM
11-10-2016 11:05 PM
did you try below.
JB
11-10-2016 11:34 PM
Yes. I did try that URL, it took me to the bug description page, but enhancement track URL appears as same tomcat error.
Thanks, Eric
11-10-2016 11:37 PM
Hi Eric,
JB
11-13-2016 08:46 PM
hi Jitender,
Thanks for your reply!!!
That was a misunderstanding. I was hoping the URL attached under CSCuz40162 was going to take me to a new enhancement page with more detailed information about Cisco 4351 gateways, rather than 4451 gateway.
Cheers, Eric
11-13-2016 08:58 PM
Glad, i was able to help.
JB
