Issue creating custom Ringtone
Andrew West
Level 4
Level 4
Hey Everyone,
I grabbed an MP3 I wanted to use as a Ringtone and converated that to RAW with Audacity.
I then modified ringlist.xml , uploaded it to the TFTP servers and restarted the service. Everything shows up and I can select that ringtone but it plays static, I can faintly hear the music I wanted in the background but the static is overwhelming which makes me think I converted from MP3 to RAW wrong.
I have been over this doc for it  http://tinyurl.com/pczhtha and as much as possible tried to meet the requirements.
I even grabbed one of the default RAW files, Piano1.raw, and tried to reverse engineer it from there but I can't seem to get it right.
Anyone have any suggestions? LIke I said I am 100% positive the issue is in the conversion from MP3 to PCM (RAW)
Bruno Rangel
Hi Andrew
Did you rename the file and uploaded it?
Can you attach you ring list and raw file here?
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
