i have successfully mated the plantronics CS55 headset with the cisco IP phone 7962. now my only issue is, when i use the headset, the audio sound is still being sent to the hand held receiver. did i configure it incorrectly? i don't think so as i am using both ports on the back of the phone (one for the headset and the other for the hand-held receiver). i am thinking there must be a way to have the audio signal not sent to the handset when i use the headset.
any ideas?
currently i am just unplugging the cord into the handset when i use the headset, but that is quite annoying.
many thanks in advance for any help.
Hi Douglas,
You are likely seeing this
If the handset is "On Hook" with the volume down a bit the problem doesn't seem to bother our users
who use the CS55 (I use one as well)
Cheers!
Rob
many thanks for taking the time to respond. i will forward this info onto our userbase. hopefully at some point in the future the software will be modified to prevent this from happening . . .
thanks again.
