419
Ronald Garcia
Beginner
Issue with CUBE
Hello friends,
I have the following scenario:
MXONE (Ericsson)<=> CUBE <=> Asterisk
The configuration of CUBE is:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
  emptycapability
  h225 id-passthru
  h245 passthru all
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  header-passing
  asserted-id pai
  midcall-signaling passthru
voice class codec 1
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  call preserve
dial-peer voice 1 voip
destination-pattern 1...
session protocol sipv2
session target ipv4:10.145.3.36
codec g711ulaw
no vad
dial-peer voice 2 voip
destination-pattern 4...
voice-class codec 1
voice-class h323 1
session target ipv4:10.145.5.100
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 voip
answer-address 1...
voice-class codec 1
no vad
dial-peer voice 4 voip
answer-address 4...
voice-class codec 1
voice-class h323 1
no vad
sip-ua
The call MXONE to Asterisk works fine, signalling and rtp.
The call Asterisk to MXONE rings but doesnt exist audio and after 5 seconds that called party answer the call is disconnect with normal clearing.
Can you help me?
Thanks in advance
2 REPLIES 2
Roger Kallberg
VIP Mentor
I guess that dial peer 1 & 3 is used for the call leg to the side that uses SIP. Please add session protocol sipv2 to DP 3, otherwise it will default to use H.323 as the transport protocol.
You should also set the appropriate dtmf relay type to be used on these dial peers.
Please remember to rate all useful posts.
Response Signature
Hello Roger,
I miss says this:
MXONE (Ericsson)<=H323 Trunk=> CUBE <=SIP Trunk=> Asterisk
Create
Recognize Your Peers
Content for Community-Ad
