1049
issue with sip 7821 phone registration CME 10.5
Dears all
i have an issue with registering cisco 7821 phones on CME 10.5 (IOS c2900-universalk9-mz.SPA.154-3.M5) and the phones have software (sip78xx.10-3-1-12) the phone keeps in registering status and dont register at all and when trying to press the settings button the screen shows XML parser error and for a while you can see the extension but not registering the configuration of the phone as follows :
ip dhcp pool Voice_pool
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
option 150 ip 192.168.20.254
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 300
voice register global
mode cme
source-address 192.168.20.254 port 5060
max-dn 100
max-pool 40
load 7821 sip78xx.10-3-1-12
authenticate register
authenticate realm all
timezone 30
hold-alert
call-forward system redirecting-expanded
phone-redirect-limit 20
tftp-path flash:
file text
create profile sync 0112233000132029
ntp-server 192.168.20.254 mode directedbroadcast
voice register dn 1
number 100
allow watch
pickup-group 100
name test
label test
mwi
voice register pool 1
busy-trigger-per-button 1
park reservation-group 1
id mac 204C.9EB3.3045
session-transport tcp
type 7821
number 1 dn 1
template 1
dtmf-relay rtp-nte
username 100 password 12345
description test
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:192.168.20.254 expires 3600 port 5060 transport udp
registrar ipv4:192.168.20.254 expires 600
tftp-server flash:sip78xx.10-3-1-12.loads
tftp-server flash:sboot78xx.10-3-1-12.sbn
tftp-server flash:sboot2.78xx.10-3-1-12.sbn
tftp-server flash:rootfs78xx.10-3-1-12.sbn
tftp-server flash:rootfs2.78xx.10-3-1-12.sbn
also all tftp statements included but so far i could not register even one phone successfully i noticed that phones have a higher Software version that is compatible with cme 10.5 could that cause a problem or it is something else ?
thanks and appreciate the help in this issue
7 REPLIES 7
Beginner
Hello Amer,
Hello Amer,
Could you check below things and let us know
1. Are the phones able to get IP address and tftp server from DHCP? Check under phone setting or on switch using "show cdp neighbour detail"
2. What is the current firmware version on IP phones? you can check under settings
3. run below debug and power reset a phone. Wait for few minutes and check if you see any activity in the logs. Share the log if you see tftp events and MAC of phone which was reset.
debug tftp events
debug ccsip message
first of all Thanks for the
first of all Thanks for the response
regarding your questions i want to answer some of it right now
Answer : Yes the phone get an IP address and tftp settings
Answer: the firmware is 10.3(1)
Answer: i will share the log today
One more thing when i try to access the settings : it give me XML parser Error 401
thanks again
Highlighted
Beginner
You can try to perform
You can try to perform factory reset on one of the phones with issue. These are brand new phones or they were used before with another CUCM/CME before?
dear mohit
dear mohit
The CME and the Phones brand new and the phones work just fine before trying to register it to the CME, the moment you try to register it keeps displaying "registering" and when trying to access the setting the message " xml parser error" appears, and i tried to register more than 1 phone and the problem keeps showing up on every phone am trying to register
thanks
hi
hi
were you able to solve this?
Participant
Henrique, are you having the
Henrique, are you having the same issue? Let me know and i can possibly tell you things to check.
worked with TAC to fix this
worked with TAC to fix this Parse Error issue.
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
no supplementary-service sip refer
fax protocol pass-through g711ulaw
h323
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 600 min 60
under the logout profile and register pool it is necessary to add the username/user and pw command.
Upgraded 7811 to the latest firmware available.
thanks !
Henrique
Content for Community-Ad
August's Community Spotlight Awards
