Walkthrough Wednesdays
166
joshreynolds
Beginner
Issues making outbound calls to certain phone numbers. 3825 Gateway, using an E1 PRI. Device & Circuit located in Germany
This is my first voice gateway deployment in Germany -  the German dial plan has proved to be challenging compared to the US dial plan.
I have a 3845 router with an E1 PRI.  Inbound/Outbound calling work fine with the exception of certain numbers.
Primarily the issue appears to impact calling certain cell phone carriers (and possibly some other numbers).
We have a E1 PRI from Deutschland Telecom.  The example number that we have problems contacting is a mobile number on O2 wireless. - Area code 176.
I have tried manipulating ISDN plan and type to all different combinations without success.
The strange thing is that the cell phone we are calling rings once, but then the call disconnect - I do not get any ringback from my devices behind the gateway.
I am attaching the output of the Q931 trace of a known good call vs the failing call (numbers scrubbed)
Anybody have experience deploying gateways in Germany?
Any help would be greatly appreciated!!
2 REPLIES 2
acampbell
Advocate
Can you try adding the following command to your global config
voice call convert-discpi-to-prog
Then retest both your good & bad calls
Alex
Regards, Alex. Please rate useful posts.
After troubleshooting, and testing different combinations of commands, I discovered the fix.
I had to disable "voice call send-alert", via global command:
no voice call send-alert
After doing this all the calls that previously were not working began working.
Josh
Content for Community-Ad
Spotlight Awards 2021
