06-05-2013 10:28 AM - edited 03-16-2019 05:43 PM
I am working at client site that has a CUCM 8.6.2 cluster. There is an issue with missed calls where the internal extension that is being called from the list is being routed incorrectly and at random to another extension in the company. The phones are 6945(9.3.1.3ES3) and 794X(42.9-2-1S) SCCP firmware.
Has anybody seen this before? Does anyone know how to troubleshoot or trace this behaviour?
Thanks in advance.
Solved! Go to Solution.
06-06-2013 10:43 AM
Hi John,
Just curious if you tried checking the CDR records for the phone
that tried dialing via the "Missed Calls" list? I'm just wondering if
perhaps they forgot to enter the prefix (like dial 9) before trying?
Maybe there is a situation where;
Missed call = something like 504-244-7897
User @ 5042 and the dial string matched @ first 4 digits if the first user forgot to edit dial 9
Just a thought
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
06-05-2013 10:33 AM
I'd start with CUCM traces to find out exactly what is being dialed by the phone.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-05-2013 11:22 AM
I would get the call traces like Jaime said and also use the dialed number analyzer to see if you are matching any translation patterns.
Yosh
06-05-2013 12:22 PM
UCM tracing is detailed enabled - everything except SCCP keepalive and device name based is on. It appears I can only run a session trace in RTMT for 60 mins and this is random occurance so I need to recreate the issue to capture the call if it fails then.
I tried to recreate but it just works for me on two other phones.
I have to find out who the calling party numbers are to run DNA.
is there another way to trace other than the session trace via RTMT?
06-05-2013 07:27 PM
Are you able to dial out using the phones in question successfully? Do the phones in question have different PTs and CSSs?
06-06-2013 09:34 AM
Hi Yahsiel,
the phones are able to dial out to each other directly. This has happened a couple times in the last couple months randomly. The same internal user is the one that always receives the mis-directed calls. The callers placing the calls are random but are all calls from the missed calls directory.
Just to give you an example, the first incident a user tried to use his missed calls directory to call someone on the PSTN and it routed the call to the same internal user I mentioned above. The phone is able to place the same call directly, but not from missed calls list.
The issue went away for a few weeks, but has returned again.
Im still working on the trace but waiting on the end user.
06-06-2013 10:43 AM
Hi John,
Just a thought
Cheers!
Rob
- The Clash
06-06-2013 12:25 PM
great point Rob!
the gateway is not prefixing 9 on inbound calls so that would make sense. I just tested this from my cell phone, but when i call from my missed calls directory it treats the call en bloc, not digit by digit analysis and the call fails. I tried this on two different models thinking it might be phone type that makes the difference but it was not.
I checked to make sure the first 4digits in my cell phone number match the 4 digit extension of a phone.
06-06-2013 12:32 PM
Hi John,
Just one further question.....were you testing this with
On-Hook dialing?
Cheers!
Rob
- The Clash
06-06-2013 12:30 PM
+5 Rob
Hope all is well
Yosh
06-06-2013 12:34 PM
Hey Yosh,
Right back at you my friend
Life is great here. How bout you?
Cheers!
Rob
- The Clash
06-06-2013 12:44 PM
Rob,
Life is good over here as well. Just found out that on May 29 Cisco announced the CCIE-Collaboration and the retirement in February of next year of the CCIE-Voice. The current voice/video offerings are:
CCNA-Video
CCNA-Voice
CCNP-Voice
CCIE-Collaboration
You can view the homepage for Cisco Certifications here: http://www.cisco.com/web/learning/certifications/index.html <http://www.cisco.com/web/learning/certifications/index.html>
Information on the CCIE-Collaboration is available at: http://www.cisco.com/web/learning/certifications/expert/ccie_collaboration/index.html <http://www.cisco.com/web/learning/certifications/expert/ccie_collaboration/index.html>
Pretty interesting stuff
Yosh
06-06-2013 01:07 PM
Hey Rob, tried both same results.
FYI - Yosh re :IE collaboration
we just got email today from Cisco SE
the latest news and release on the new IE collaboration migration is you can convert your IE cert by just writing the written exam only NO lab required - webiste isnt updated to reflect this yet.
There was alot of back and forth on this not sure if you are up to date or not so just thought I would share my latest.
06-06-2013 01:24 PM
so i just pulled up the CNA to check the NXX range within 780 area code and the range 200-299 exists.
the users extension is 7802
so it is very logical that from the missed calls directory a number like 7802XX- XXXX would match 7802 and ring that DN, but i cant seem to recreate that because the phone is not dialing digit by digit.
Any thoughts?
06-06-2013 01:40 PM
This is the doc I found for firmware 8.4 - anything prior to this used digit by digit dialing for SCCP
In previous IP Phone firmware versions, when dialing a number on-hook, from a call record (missed, placed or received), or from directories, the Cisco Unified IP Phone would play out each digit sequentially. This introduced a dialing delay. If the keypad was pressed during dialing, the digits could be inserted into the dial string incorrectly.
This has been resolved by sending all of the digits dialed on-hook, or from a call record in a single dial string (En-bloc Dialing), similar to cell phone dialing. The user will no longer hear each digit dialed sequentially.http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCso95186
Note En-bloc dialing behavior is not configurable.
