08-29-2016 07:26 AM - edited 03-17-2019 07:57 AM
I am trying to install a NIM-2FXO voice card in a Cisco series 4300 router, IOS XE Software ver 03.13.04.S.
Where do I start...........I am trying to get the card installed, then allow our Call manager system to use the voice ports for our 911.
I have been successful getting this process to work on older 2811 and 2901 routers but this 4300 router is giving me fits.
I have included a sh ver of the router
Router#sh ver Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4, RELEASE SOFTWARE (fc3) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2015 by Cisco Systems, Inc. Compiled Mon 05-Oct-15 11:24 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc. All rights reserved. Certain components of Cisco IOS-XE software are licensed under the GNU General Public License ("GPL") Version 2.0. The software code licensed under GPL Version 2.0 is free software that comes with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such GPL code under the terms of GPL Version 2.0. For more details, see the documentation or "License Notice" file accompanying the IOS-XE software, or the applicable URL provided on the flyer accompanying the IOS-XE software.
ROM: IOS-XE ROMMON
Router uptime is 16 hours, 2 minutes Uptime for this control processor is 16 hours, 4 minutes System returned to ROM by reload at 15:42:27 EDT Thu Aug 25 2016 System image file is "bootflash:/isr4300-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin" Last reload reason: Reload Command
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to export@cisco.com.
Technology Package License Information:
----------------------------------------------------------------- Technology Technology-package Technology-package Current Type Next reboot ------------------------------------------------------------------ appx None None None uc None None None security None None None ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1687137K/6147K bytes of memory. Processor board ID FLM2030W1W7 3 Gigabit Ethernet interfaces 2 Voice FXS interfaces 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 3207167K bytes of flash memory at bootflash:.
Thanks for your help in advance
08-29-2016 07:38 AM
What do you see when you do a "show inventory"?
10-24-2016 09:35 AM
Thanks for your help. It was a licensing issue. Once we installed the correct license, the NIM started working as it should.
