11-27-2014 06:22 AM - edited 03-17-2019 01:07 AM
Hello I am looking at the below issues which is affecting users only in a team in a specific hunt-group --
When a voicemail is received all the phones could not use the message button on the phones.
Voicemail light indicator on the phone goes off when it is hear using the email attachment.
Any reason this could be happening?
Any pointers will be much appreciated.
11-27-2014 07:25 AM
You need to mention what call control and VM system you're using, and not just the problem.
11-27-2014 07:51 AM
Sorry about that.
VM Profile has been named as follows:
NoVoiceMail (used by 241 devices) | |
NoVoiceMail | |
No Voice Mail | |
< None >/< None > | |
Phones are 7942 Cisco IP Phones registered to call Manager.
11-28-2014 07:29 AM
can you explain more about the configuration of the Unity Connection?! Is there a exchange integration (MAPI) or is the delivery to Email via IMAP only ?
Also did you have define a Call Forward Information in CUCM (HuntPilot). I mean you have to give us more information about your configuration.
Just for example! You can set a Call Forward no Answer in CUCM to 999X ... SIP Trunk to Unity Connection Matching RoutePattern 999X
In CUC you cofigure an Forward Filter with called party 999X -> Go to System Handler and Configure your desired Solution....perhabs a Message like a "small" IVR .... pressing 1 Go ... Pressing 2 ... Go.... and so on....
It depends on customer what he want--
greetz,
/Stefan
12-10-2014 01:45 AM
Thanks for your advise. i do not have much access to carry on troubleshooting so have forwarded to the relevant team.
thanks again
