1865
Guillaume Roche
Beginner
%IVR-3-LOW_CPU_RESOURCE
i recently upgraded my voice gateway (2811) to 15.1(4)M10 sp services .
But since, i have a lot of errors :
Jul 30 11:51:37: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16444) is rejected.
Jul 30 21:31:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16505) is rejected.
Jul 30 21:32:31: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16506) is rejected.
Jul 30 21:34:06: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16509) is rejected.
Jul 30 21:34:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16510) is rejected.
Jul 30 21:34:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16511) is rejected.
Jul 30 21:36:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16512) is rejected.
Jul 30 21:37:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16513) is rejected.
I saw no bug for this. I have the last IOS. Somebody can help me please ?
Best regards,
Guillaume
3 REPLIES 3
Nadeem Ahmed
can you please attached show tech from router  along with this output.
show processes cpu sort 1min
show processes cpu history
show interfaces
show align
show interfaces summary
show interfaces switching
show ip cef switching statistics
show ip cef switching statistics feature
show ip interface
show ip traffic
show policy-map int
show log
Br, Nadeem Please rate all useful post.
CPU utilization for five seconds: 90%/28%; one minute: 68%; five minutes: 69%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
123 594231224 385455705 1541 44.07% 40.52% 41.56% 0 IP Input
98 1833872 152050713 12 0.71% 0.73% 0.72% 0 Ethernet Msec Ti
350 7746484 2824144 2742 8.79% 0.72% 0.43% 0 SNMP ENGINE
154 1708992 74927349 22 0.55% 0.52% 0.53% 0 HSRP Common
270 1862664 4645907 400 0.39% 0.34% 0.32% 0 Skinny Msg Serve
282 3661964 5796265 631 3.67% 0.30% 0.15% 0 IP SNMP
205 1132688 60180624 18 0.31% 0.24% 0.24% 0 MGCP App STW Tic
119 608756 40418545 15 0.15% 0.16% 0.15% 0 IPAM Manager
6 2459584 247474 9938 0.00% 0.13% 0.15% 0 Check heaps
319 386852 366738 1054 0.31% 0.12% 0.13% 0 CCH323_CT
308 219152 486754 450 0.07% 0.12% 0.14% 0 DSMP
310 179296 373974 479 0.15% 0.11% 0.13% 0 VOIP_RTCP
12 734672 21674241 33 0.07% 0.10% 0.10% 0 MGCP Application
355 668 343 1947 0.63% 0.09% 0.05% 515 Virtual Exec
30 1008012 1782840 565 0.07% 0.08% 0.07% 0 ARP Input
349 914988 2820657 324 1.03% 0.08% 0.01% 0 PDU DISPATCHER
299 762940 62792 12150 0.00% 0.06% 0.05% 0 Per-minute Jobs
134 6688 7016 953 0.00% 0.06% 0.06% 0 AFW_application_
336 749160 4432905 168 0.07% 0.04% 0.05% 0 HSRP IPv4
331 134936 56026 2408 0.00% 0.04% 0.05% 0 ISDN
2 228472 273386 835 0.07% 0.04% 0.02% 0 Load Meter
309 85408 159244 536 0.00% 0.03% 0.02% 0 VTSP
97 115604 8831858 13 0.07% 0.02% 0.02% 0 Ethernet Timer C
50 35384 1363019 25 0.07% 0.02% 0.00% 0 TTY Background
300 111744 1392507 80 0.00% 0.02% 0.00% 0 Per-Second Jobs
152 253364 22796 11114 0.00% 0.02% 0.00% 0 Licensing Auto U
329 106056 5467699 19 0.00% 0.02% 0.00% 0 e1t1 Framer back
138 93052 5339570 17 0.00% 0.02% 0.00% 0 SSS Feature Time
254 116676 6834579 17 0.00% 0.02% 0.00% 0 Atheros LED Ctro
345 117748 682230 172 0.07% 0.02% 0.00% 0 ISDN L2 Process
293 55268 33521 1648 0.00% 0.02% 0.00% 0 Syslog
67 85524 5467699 15 0.07% 0.01% 0.00% 0 Netclock Backgro
298 54376 278075 195 0.07% 0.01% 0.00% 0 Compute load avg
347 74932 485909 154 0.00% 0.01% 0.00% 0 ISDN L2D SRQ Pro
335 75836 510902 148 0.00% 0.01% 0.00% 0 ISDN From Driver
344 71988 1406107 51 0.00% 0.00% 0.00% 0 NTP
47 87072 466336 186 0.00% 0.00% 0.00% 0 Net Background
330 84760 169073 501 0.00% 0.00% 0.00% 0 DHCPD Receive
17 21628 1330326 16 0.07% 0.00% 0.00% 0 IPC Periodic Tim
31 39364 1426553 27 0.00% 0.00% 0.00% 0 ARP Background
18 19468 1330332 14 0.00% 0.00% 0.00% 0 IPC Deferred Por
175 12072 1363049 8 0.00% 0.00% 0.00% 0 bsm_xmt_proc
306 12068 27962 431 0.00% 0.00% 0.00% 0 CC-API_VCM
7 57880 25622 2258 0.00% 0.00% 0.00% 0 Pool Manager
160 6972 39778 175 0.00% 0.00% 0.00% 0 TCP Timer
261 15372 81689 188 0.00% 0.00% 0.00% 0 EEM ED Syslog
42 21092 1366925 15 0.00% 0.00% 0.00% 0 GraphIt
313 19996 52297 382 0.00% 0.00% 0.00% 0 TSP
49 14516 64920 223 0.00% 0.00% 0.00% 0 Logger
41 0 2 0 0.00% 0.00% 0.00% 0 SMART
51 1512 91107 16 0.00% 0.00% 0.00% 0 c2800 Periodic
52 3500 18183 192 0.00% 0.00% 0.00% 0 IF-MGR control p
53 1404 15242 92 0.00% 0.00% 0.00% 0 IF-MGR event pro
54 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
55 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
56 0 1 0 0.00% 0.00% 0.00% 0 Token Daemon
46 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
58 14664 398387 36 0.00% 0.00% 0.00% 0 HC Counter Timer
48 0 2 0 0.00% 0.00% 0.00% 0 IDB Work
60 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov
61 0 1 0 0.00% 0.00% 0.00% 0 sal_dpc_process
45 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
63 0 2 0 0.00% 0.00% 0.00% 0 ESWPPM
64 0 2 0 0.00% 0.00% 0.00% 0 Eswilp Storm Con
65 0 2 0 0.00% 0.00% 0.00% 0 ESWILPPM
66 0 2 0 0.00% 0.00% 0.00% 0 Eswilp Storm Con
40 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
68 0 2 0 0.00% 0.00% 0.00% 0 SM Monitor
69 0 2 0 0.00% 0.00% 0.00% 0 Bryce I2C CMD Qu
44 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
57 292 19583 14 0.00% 0.00% 0.00% 0 Transport Port A
43 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
73 148 25 5920 0.00% 0.00% 0.00% 0 FLEX DNLD MAIN
74 0 1 0 0.00% 0.00% 0.00% 0 HDV background
59 0 1 0 0.00% 0.00% 0.00% 0 dev_device_inser
62 0 1 0 0.00% 0.00% 0.00% 0 ARL Table Manage
77 28 1 28000 0.00% 0.00% 0.00% 0 AAL2_XGCPSPI
78 12312 1363044 9 0.00% 0.00% 0.00% 0 Ether-Switch RBC
79 0 1 0 0.00% 0.00% 0.00% 0 IGMP Snooping Pr
80 0 1 0 0.00% 0.00% 0.00% 0 IGMP Snooping Re
70 3132 227708 13 0.00% 0.00% 0.00% 0 mxt5100
82 276 4 69000 0.00% 0.00% 0.00% 0 USB Startup
83 0 1 0 0.00% 0.00% 0.00% 0 AAL2CPS TIMER_CU
84 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
85 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
86 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
87 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
88 920 22781 40 0.00% 0.00% 0.00% 0 DFS flush period
89 4 2 2000 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces
90 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework
91 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework
92 0 2 0 0.00% 0.00% 0.00% 0 DTP Protocol
93 12932 1363037 9 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
94 1412 136651 10 0.00% 0.00% 0.00% 0 EtherChnl
95 0 2 0 0.00% 0.00% 0.00% 0 call_home_les_oi
96 0 2 0 0.00% 0.00% 0.00% 0 Ethernet CFM
71 4 2 2000 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN
15 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv
72 0 1 0 0.00% 0.00% 0.00% 0 DSPFARM DSP READ
100 0 1 0 0.00% 0.00% 0.00% 0 SMI CDP Update H
75 8132 45558 178 0.00% 0.00% 0.00% 0 EEM ED ND
102 16968 1363049 12 0.00% 0.00% 0.00% 0 linktest
103 0 2 0 0.00% 0.00% 0.00% 0 Dot11 Mgmt & Ass
104 0 2 0 0.00% 0.00% 0.00% 0 Dot11 aaa proces
105 624 22781 27 0.00% 0.00% 0.00% 0 pmkid
106 0 2 0 0.00% 0.00% 0.00% 0 Dot11 auth Dot1x
107 0 1 0 0.00% 0.00% 0.00% 0 Dot11 Mac Auth
76 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Identity
109 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
81 4 103 38 0.00% 0.00% 0.00% 0 Call Management
111 39448 210775 187 0.00% 0.00% 0.00% 0 CDP Protocol
112 4 2 2000 0.00% 0.00% 0.00% 0 AAA Dictionary R
113 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
114 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
115 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
116 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
117 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
118 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
39 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
120 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
121 340 841 404 0.00% 0.00% 0.00% 0 IP ARP Adjacency
122 4 1 4000 0.00% 0.00% 0.00% 0 IP ARP Retry Age
13 3220 273223 11 0.00% 0.00% 0.00% 0 IPC Event Notifi
124 0 61 0 0.00% 0.00% 0.00% 0 ICMP event handl
125 0 3 0 0.00% 0.00% 0.00% 0 PIM register asy
126 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
127 0 2 0 0.00% 0.00% 0.00% 0 OCE punted Pkts
128 0 1 0 0.00% 0.00% 0.00% 0 LSP Tunnel FRR
129 0 1 0 0.00% 0.00% 0.00% 0 MPLS Auto-Tunnel
130 228 2274 100 0.00% 0.00% 0.00% 0 MOP Protocols
131 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
132 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
133 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
38 1960 14 140000 0.00% 0.00% 0.00% 0 PrstVbl
135 0 1 0 0.00% 0.00% 0.00% 0 SSS Manager
136 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
137 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
37 4 2 2000 0.00% 0.00% 0.00% 0 Entity MIB API
139 0 2 0 0.00% 0.00% 0.00% 0 Spanning Tree
140 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
141 0 24 0 0.00% 0.00% 0.00% 0 SSM connection m
142 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
143 0 2 0 0.00% 0.00% 0.00% 0 Ethernet LMI
144 0 1 0 0.00% 0.00% 0.00% 0 FRR Background P
145 1764 27758 63 0.00% 0.00% 0.00% 0 CEF background p
146 0 1 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
147 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant
148 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant
149 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant
150 0 1 0 0.00% 0.00% 0.00% 0 IPC UDP Input
151 0 1 0 0.00% 0.00% 0.00% 0 Asy FS Helper
99 0 1 0 0.00% 0.00% 0.00% 0 SMI Director DB
153 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
11 0 1 0 0.00% 0.00% 0.00% 0 License Client N
155 0 2 0 0.00% 0.00% 0.00% 0 ADJ background
101 0 1 0 0.00% 0.00% 0.00% 0 SMI Backup Proce
157 0 1 0 0.00% 0.00% 0.00% 0 MRD
158 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN
159 0 2 0 0.00% 0.00% 0.00% 0 L2X Switching Ev
108 28 164 170 0.00% 0.00% 0.00% 0 AAA Server
161 3104 11907 260 0.00% 0.00% 0.00% 0 TCP Protocols
162 444 5142 86 0.00% 0.00% 0.00% 0 HTTP CORE
163 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
164 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology
165 8 5 1600 0.00% 0.00% 0.00% 0 IP RIB Update
166 576 22976 25 0.00% 0.00% 0.00% 0 IP Background
167 24 23 1043 0.00% 0.00% 0.00% 0 IP Connected Rou
168 0 2 0 0.00% 0.00% 0.00% 0 RLM groups Proce
169 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
170 0 2 0 0.00% 0.00% 0.00% 0 SNMP Timers
171 8 2 4000 0.00% 0.00% 0.00% 0 SCTP Main Proces
172 0 1 0 0.00% 0.00% 0.00% 0 IUA Main Process
173 25872 1369335 18 0.00% 0.00% 0.00% 0 RUDPV1 Main Proc
110 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
10 72 792 90 0.00% 0.00% 0.00% 0 WATCH_AFS
176 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Inp
9 0 2 0 0.00% 0.00% 0.00% 0 Timers
14 404 22782 17 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
179 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder
180 0 2 0 0.00% 0.00% 0.00% 0 ADJ resolve proc
181 0 3 0 0.00% 0.00% 0.00% 0 Flow Exporter Ti
182 516 22944 22 0.00% 0.00% 0.00% 0 Call Home Timer
35 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
184 0 3 0 0.00% 0.00% 0.00% 0 MFIB Master back
185 808 6459 125 0.00% 0.00% 0.00% 0 RARP Input
186 4 4 1000 0.00% 0.00% 0.00% 0 static
187 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
188 0 1 0 0.00% 0.00% 0.00% 0 LAPB Process
189 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Inspect Tim
190 0 4 0 0.00% 0.00% 0.00% 0 Inter Chassis Pr
191 0 2 0 0.00% 0.00% 0.00% 0 LFDp Input Proc
192 0 2 0 0.00% 0.00% 0.00% 0 PPP NBF
193 35492 1340150 26 0.00% 0.00% 0.00% 0 PfR BR Learn
194 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
195 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
36 636 8747 72 0.00% 0.00% 0.00% 0 DDR Timers
197 0 2 0 0.00% 0.00% 0.00% 0 HQF Shaper Backg
198 0 3 0 0.00% 0.00% 0.00% 0 RBSCP Background
199 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
200 1268 54679 23 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_
201 116 2 58000 0.00% 0.00% 0.00% 0 CCVPM_HDSPRM
202 0 4 0 0.00% 0.00% 0.00% 0 HDA DSPRM MAIN
203 0 2 0 0.00% 0.00% 0.00% 0 STUN_APP
204 0 1 0 0.00% 0.00% 0.00% 0 STUN_TEST
8 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
206 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
207 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
208 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
209 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
210 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
211 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
212 92 164 560 0.00% 0.00% 0.00% 0 LOCAL AAA
213 0 2 0 0.00% 0.00% 0.00% 0 MPLS Auto Mesh P
214 4 2 2000 0.00% 0.00% 0.00% 0 TPLUS
215 0 2 0 0.00% 0.00% 0.00% 0 VSP_MGR
216 304888 118823 2565 0.00% 0.00% 0.00% 0 NIST rng proc
217 8 3 2666 0.00% 0.00% 0.00% 0 Crypto WUI
218 0 3 0 0.00% 0.00% 0.00% 0 LDAP process
219 324 416 778 0.00% 0.00% 0.00% 0 CCVPM_HTSP
220 0 2 0 0.00% 0.00% 0.00% 0 VPM_MWI_BACKGROU
221 8420 136639 61 0.00% 0.00% 0.00% 0 VPM_CABLE_STAT_P
222 0 1 0 0.00% 0.00% 0.00% 0 VPM_CONN_CHK_BAC
223 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2
224 0 5 0 0.00% 0.00% 0.00% 0 IP TRUST Registe
225 0 1 0 0.00% 0.00% 0.00% 0 EPHONE MWI Refre
226 20 1519 13 0.00% 0.00% 0.00% 0 FB/KS Log HouseK
227 0 2 0 0.00% 0.00% 0.00% 0 EPHONE MWI BG Pr
228 0 1 0 0.00% 0.00% 0.00% 0 Skinny HW confer
229 90924 1010444 89 0.00% 0.00% 0.00% 0 FLEX DSPRM MAIN
230 19016 505181 37 0.00% 0.00% 0.00% 0 FLEX DSP KEEPALI
231 0 2 0 0.00% 0.00% 0.00% 0 CTI Front End Pr
232 0 2 0 0.00% 0.00% 0.00% 0 CTI Call Control
233 0 2 0 0.00% 0.00% 0.00% 0 CTI Line Monitor
234 0 1 0 0.00% 0.00% 0.00% 0 CME CTI Device M
235 3120 45666 68 0.00% 0.00% 0.00% 0 VOICE REG BG Pro
236 27244 1366927 19 0.00% 0.00% 0.00% 0 CME Extension Mo
237 0 1 0 0.00% 0.00% 0.00% 0 Presence Process
238 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE
239 12 60 200 0.00% 0.00% 0.00% 0 MGCP App DNS
240 0 1 0 0.00% 0.00% 0.00% 0 http client proc
241 8 23 347 0.00% 0.00% 0.00% 0 TCP Driver
242 0 2 0 0.00% 0.00% 0.00% 0 CSDB Timer proce
243 4 1 4000 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN
244 0 1 0 0.00% 0.00% 0.00% 0 RPMS_PROC_MAIN
245 0 1 0 0.00% 0.00% 0.00% 0 VoIP AAA
246 0 2 0 0.00% 0.00% 0.00% 0 Dialog Manager
247 0 2 0 0.00% 0.00% 0.00% 0 crypto engine pr
248 4 4 1000 0.00% 0.00% 0.00% 0 Crypto CA
249 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
250 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
251 881660 74354 11857 0.00% 0.00% 0.00% 0 crypto sw pk pro
252 0 1 0 0.00% 0.00% 0.00% 0 PM Callback
253 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr
34 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
255 0 2 0 0.00% 0.00% 0.00% 0 Control-plane ho
256 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr
257 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector
258 6540 17624 371 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
259 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client
260 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Routing
156 0 3 0 0.00% 0.00% 0.00% 0 L2MM
262 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Track
263 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Resource
264 1576 136649 11 0.00% 0.00% 0.00% 0 RMON Recycle Pro
265 0 2 0 0.00% 0.00% 0.00% 0 RMON Deferred Se
266 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
267 32 116 275 0.00% 0.00% 0.00% 0 EEM Server
268 576 4471 128 0.00% 0.00% 0.00% 0 VLAN Manager
269 440 11420 38 0.00% 0.00% 0.00% 0 DHCPD Timer
174 0 1 0 0.00% 0.00% 0.00% 0 bsm_timers
271 34640 1339179 25 0.00% 0.00% 0.00% 0 trunk conditioni
272 0 1 0 0.00% 0.00% 0.00% 0 trunk conditioni
273 24 2 12000 0.00% 0.00% 0.00% 0 Call Home proces
274 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
275 0 3 0 0.00% 0.00% 0.00% 0 Collection proce
276 0 3 0 0.00% 0.00% 0.00% 0 EEM ED CLI
277 4 3 1333 0.00% 0.00% 0.00% 0 EEM ED Counter
278 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Interface
279 0 3 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
280 4 3 1333 0.00% 0.00% 0.00% 0 EEM ED None
281 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR
5 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
283 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
284 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje
285 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla
286 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
287 1032 35362 29 0.00% 0.00% 0.00% 0 EEM ED Timer
288 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test
289 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Config
290 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env
291 4 3 1333 0.00% 0.00% 0.00% 0 EM ED GOLD
292 4 2 2000 0.00% 0.00% 0.00% 0 EEM ED Nf
33 0 1 0 0.00% 0.00% 0.00% 0 ATM ASYNC PROC
294 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Ethernet
295 4332 273223 15 0.00% 0.00% 0.00% 0 VDC process
296 0 3 0 0.00% 0.00% 0.00% 0 EEM ED RPC
297 150760 1175227 128 0.00% 0.00% 0.00% 0 Net Input
32 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
16 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
29 16844 45558 369 0.00% 0.00% 0.00% 0 Environmental mo
301 0 2 0 0.00% 0.00% 0.00% 0 MRIB Process
302 23036 1394257 16 0.00% 0.00% 0.00% 0 TRP_PSEUDOTIMER
303 4872 56123 86 0.00% 0.00% 0.00% 0 Resource Monitor
304 0 2 0 0.00% 0.00% 0.00% 0 Resource Availab
305 0 3 0 0.00% 0.00% 0.00% 0 TRPAPP
178 0 1 0 0.00% 0.00% 0.00% 0 COPS
307 0 2 0 0.00% 0.00% 0.00% 0 confmsp
4 4 1 4000 0.00% 0.00% 0.00% 0 EDDRI_MAIN
28 0 1 0 0.00% 0.00% 0.00% 0 Exception contro
3 4 1 4000 0.00% 0.00% 0.00% 0 LICENSE AGENT
311 16 6 2666 0.00% 0.00% 0.00% 0 Session Applicat
312 4 2 2000 0.00% 0.00% 0.00% 0 swmtp_msp
196 0 1 0 0.00% 0.00% 0.00% 0 MQC Flow Event B
314 0 1 0 0.00% 0.00% 0.00% 0 lib_off_app
315 4 2 2000 0.00% 0.00% 0.00% 0 Voice Player
316 0 1 0 0.00% 0.00% 0.00% 0 Media Record
317 0 1 0 0.00% 0.00% 0.00% 0 Resource Measure
318 0 1 0 0.00% 0.00% 0.00% 0 tHUB
27 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
320 0 1 0 0.00% 0.00% 0.00% 0 CCH323_DNS
321 44 3 14666 0.00% 0.00% 0.00% 0 CCSIP_SPI_CONTRO
322 0 1 0 0.00% 0.00% 0.00% 0 CCSIP_DNS
323 4 2 2000 0.00% 0.00% 0.00% 0 CCSIP_UDP_SOCKET
324 8 2 4000 0.00% 0.00% 0.00% 0 CCSIP_TCP_SOCKET
325 536 22895 23 0.00% 0.00% 0.00% 0 RTPSPI
326 4 2 2000 0.00% 0.00% 0.00% 0 CCFRF11_CT
327 20 2 10000 0.00% 0.00% 0.00% 0 CCAAL2_CT
328 140 759 184 0.00% 0.00% 0.00% 0 SSH Event handle
26 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
25 7468 273265 27 0.00% 0.00% 0.00% 0 IPC Loadometer
24 2076 136694 15 0.00% 0.00% 0.00% 0 IPC Keep Alive M
332 0 2 0 0.00% 0.00% 0.00% 0 ISDN Timer
333 120 5506 21 0.00% 0.00% 0.00% 0 ISDNMIB Backgrou
334 776 16356 47 0.00% 0.00% 0.00% 0 CallMIB Backgrou
23 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
22 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
337 0 1 0 0.00% 0.00% 0.00% 0 MGCP App TFTP
338 3588 38387 93 0.00% 0.00% 0.00% 0 Call Manager App
339 30500 1140 26754 0.00% 0.00% 0.00% 0 Call Manager XML
341 4 3 1333 0.00% 0.00% 0.00% 0 IPv6 RIB Event H
342 0 2 0 0.00% 0.00% 0.00% 0 Skinny MOH Event
343 0 66 0 0.00% 0.00% 0.00% 0 Skinny Socket Se
21 1168 78093 14 0.00% 0.00% 0.00% 0 IPC Check Queue
20 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
346 1684 23959 70 0.00% 0.00% 0.00% 0 ISDN L3 Timer Pr
19 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
348 336 22781 14 0.00% 0.00% 0.00% 0 DHCPD Database
183 0 2 0 0.00% 0.00% 0.00% 0 Multicast Offloa
1 48 99 484 0.00% 0.00% 0.00% 0 Chunk Manager
351 0 1 0 0.00% 0.00% 0.00% 0 IP SNMPV6
352 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
353 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
177 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Res
#show processes cpu history
RPARC_C2801_FW1 09:29:17 AM Monday Aug 1 2016 UTC
666666666666665555555555555555555566666777777777777777777776
777777777222227777799999888888888855555888882222211111000006
100
90
80 *****
70 ********* **************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
778977796568986348396786798987789998999899999889877886575978
879264954865707613631334289631977734786945845614426377806671
100 * * * * ** *** ** * *
90 ** * *# * *** **#* ###*#*##** * * *
80 ***** ** *#* * * * **#* *##############**** *** ***
70 ###**#*# *##** * * ** *###***##################*##** * ***
60 ########***###* * #**##############################*#***#**
50 ##########*#### * #####################################*#**
40 ###############**#*#########################################
30 ############################################################
20 ############################################################
10 ############################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
989999999999888898899889999999999999778779999999999999999999988999998999
818888988899967828745682617888988799421046899999999999988899498788875468
100 * *########* * * *#######** **###############** ***** **
90 * #########****************########* *#################*************
80 **#########****************########* * *#################*************
70 **#########****************########*******#################*************
60 **#########****************########*******#################*******#****#
50 #*#########********#####**#########******##################*##**###***##
40 #*#########*#######################******##################*##*####**###
30 #*#################################******#####################*#########
20 #*##################################*****###############################
10 ########################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0026.9992.dff8 (bia 0026.9992.dff8)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
Internet address is xxx.yy.50.251/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/564/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 140000 bits/sec, 30 packets/sec
5 minute output rate 154000 bits/sec, 27 packets/sec
39234869 packets input, 1045108065 bytes
Received 626517 broadcasts (0 IP multicasts)
0 runts, 0 giants, 41 throttles
540 input errors, 0 CRC, 0 frame, 0 overrun, 540 ignored
0 watchdog
30579742 packets output, 2881687258 bytes, 0 underruns
45515 unknown protocol drops
0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0026.9992.dff9 (bia 0026.9992.dff9)
reliability 254/255, txload 4/255, rxload 4/255
Input queue: 4/75/294935/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 1917000 bits/sec, 802 packets/sec
5 minute output rate 1602000 bits/sec, 624 packets/sec
1151747080 packets input, 3030877014 bytes
Received 9023117 broadcasts (0 IP multicasts)
0 runts, 0 giants, 178709 throttles
5778331 input errors, 0 CRC, 0 frame, 0 overrun, 5778331 ignored
0 watchdog
1132721907 packets output, 636052192 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
1332435 unknown protocol drops
1 lost carrier, 0 no carrier
FastEthernet0/1.1 is up, line protocol is up
Internet address is xxx.yy.100.251/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 1.
FastEthernet0/1.10 is up, line protocol is up
Internet address is xxx.yy.10.251/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 10.
FastEthernet0/1.12 is up, line protocol is up
Internet address is xxx.yy.1.251/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 12.
FastEthernet0/1.20 is up, line protocol is up
Encapsulation 802.1Q Virtual LAN, Vlan ID 20.
FastEthernet0/1.99 is up, line protocol is up
Internet address is xxx.yy.99.251/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 99.
FastEthernet0/1.100 is up, line protocol is up
Internet address is 10.10.yy.2/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 100.
FastEthernet0/1.199 is up, line protocol is up
Encapsulation 802.1Q Virtual LAN, Vlan ID 199.
FastEthernet0/1.250 is up, line protocol is up
Internet address is xxx.24.1.254/16
Encapsulation 802.1Q Virtual LAN, Vlan ID 250.
Serial0/0/0:0 is up, line protocol is up
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive not set
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
Serial0/0/0:1 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:2 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:3 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:4 is down, line protocol is down
Hardware is DSX1
Keepalive not set
Serial0/0/0:5 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:6 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:7 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:8 is down, line protocol is down
Hardware is DSX1
Keepalive not set
Serial0/0/0:9 is up, line protocol is up
Hardware is DSX1
Keepalive not set
Serial0/0/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
Last input 00:00:03, output never, output hang never
Conversations 0/1/256 (active/max active/max total)
258838 packets input, 1478324 bytes, 0 no buffer
258838 packets output, 1326344 bytes, 0 underruns
1 carrier transitions
Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
#show align
No alignment data has been recorded.
No spurious memory references have been recorded.
#show interfaces summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* FastEthernet0/0 0 564 0 0 116000 33 145000 28 41
* FastEthernet0/1 9 294958 0 0 1915000 837 1595000 662 178717
* FastEthernet0/1.1 - - - - - - - - -
* FastEthernet0/1.10 - - - - - - - - -
* FastEthernet0/1.12 - - - - - - - - -
* FastEthernet0/1.20 - - - - - - - - -
* FastEthernet0/1.99 - - - - - - - - -
* FastEthernet0/1.100 - - - - - - - - -
* FastEthernet0/1.199 - - - - - - - - -
* FastEthernet0/1.250 - - - - - - - - -
* Serial0/0/0:0 0 0 0 0 0 0 0 0 0
* Serial0/0/0:1 0 0 0 0 0 0 0 0 0
* Serial0/0/0:2 0 0 0 0 0 0 0 0 0
* Serial0/0/0:3 0 0 0 0 0 0 0 0 0
* Serial0/0/0:4 0 0 0 0 0 0 0 0 0
* Serial0/0/0:5 0 0 0 0 0 0 0 0 0
* Serial0/0/0:6 0 0 0 0 0 0 0 0 0
* Serial0/0/0:7 0 0 0 0 0 0 0 0 0
* Serial0/0/0:8 0 0 0 0 0 0 0 0 0
* Serial0/0/0:9 0 0 0 0 0 0 0 0 0
* Serial0/0/0:15 0 0 0 0 0 0 0 0 0
NOTE:No separate counters are maintained for subinterfaces
Hence Details of subinterface are not shown
#show interfaces switching
FastEthernet0/0 $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
Throttle count 41
Drops RP 564 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 29873 Drops 0
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 39162331 1039254107 30412955 2875667469
Cache misses 0 - - -
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol DEC MOP
Process 0 0 2271 174867
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 29873 1792380 26314 1578840
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 22771 8812377 25287 10291809
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 45537 2732220 136589 8195340
Fast 0 0 0 0
Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
FastEthernet0/1
Throttle count 178796
Drops RP 295166 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 3586708 Drops 0
Protocol IP
Process 1149077673 2701869582 1132034980 698891953
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol DEC MOP
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 1882924 112998180 1009236 64585952
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 22731 9274248 25275 10337475
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 1333086 88044969 136589 8195340
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Serial0/0/0:0
All statistics for this interface are zero.
Serial0/0/0:1
Serial0/0/0:2
Serial0/0/0:3
Serial0/0/0:4
Serial0/0/0:5
Serial0/0/0:6
Serial0/0/0:7
Serial0/0/0:8
Serial0/0/0:9
Serial0/0/0:15
Protocol Other
Process 0 0 259144 1328770
Fast 0 0 0 0
Auton/SSE 0 0 0 0
#show ip cef switching statistics
Reason Drop Punt Punt2Host
All Total 0 0 0
#show ip cef switching statistics feature
IPv4 CEF input features:
Feature Drop Consume Punt Punt2Host Gave route
Total 0 0 0 0 0
IPv4 CEF output features:
Feature Drop Consume Punt Punt2Host New i/f
Total 0 0 0 0 0
IPv4 CEF post-encap features:
Total 0 0 0 0 0
IPv4 CEF for us features:
Total 0 0 0 0 0
IPv4 CEF punt features:
Total 0 0 0 0 0
IPv4 CEF local features:
Total 0 0 0 0 0
show ip interface
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.2
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is disabled
BGP Policy Mapping is disabled
Input features: MCI Check
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
Internet protocol processing disabled
MTU is 1500 bytes
IP fast switching on the same interface is enabled
MTU is 1500 bytes
MTU is 1500 bytes
Helper addresses are xxx.yy.1.10
xxx.yy.1.11
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1500 bytes
Serial0/0/0:4 is up, line protocol is up
Serial0/0/0:6 is down, line protocol is down
Serial0/0/0:7 is down, line protocol is down
show ip traffic
IP statistics:
Rcvd: 1231572062 total, 54094331 local destination
0 format errors, 0 checksum errors, 3 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 fragments, 0 couldn't fragment
Bcast: 3790007 received, 2945 sent
Mcast: 4432444 received, 3973868 sent
Sent: 7542644 generated, 1154769215 forwarded
Drop: 1835385 encapsulation failed, 0 unresolved, 0 no adjacency
0 no route, 0 unicast RPF, 0 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 0 packets with internal loop back IP address
1479 physical broadcast
Reinj: 0 in input feature path, 0 in output feature path
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 12936 unreachable
100247 echo, 2 echo reply, 0 mask requests, 0 mask replies, 0 quench
0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
0 irdp solicitations, 0 irdp advertisements
0 time exceeded, 0 info replies
Sent: 0 redirects, 4680 unreachable, 60 echo, 100247 echo reply
0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
0 info reply, 3 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 246608 total, 0 checksum errors, 3349 no port
Sent: 239173 total
UDP statistics:
Rcvd: 53734538 total, 0 checksum errors, 1662788 no port
Sent: 7198535 total, 985762 forwarded broadcasts
BGP statistics:
Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
0 keepalives, 0 route-refresh, 0 unrecognized
Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
Rcvd: 0 total
Sent: 0 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
OSPF statistics:
Last clearing of OSPF traffic counters never
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 1901241 requests, 3071 replies, 6461 reverse, 0 other
Sent: 500402 requests, 535691 replies (375 proxy), 0 reverse
Drop due to input queue full: 0
#show policy-map int
#sh log
Syslog logging: enabled (0 messages dropped, 102 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 127091 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 1802 messages logged, xml disabled,
filtering disabled
Buffer logging: level warnings, 669 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 51792 message lines logged
Logging to 172.22.1.112 (udp port 514, audit disabled,
link up),
51792 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging to 172.22.1.51 (udp port 514, audit disabled,
link up),
filtering disabled
Logging Source-Interface: VRF Name:
Log Buffer (51200 bytes):
CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8455) is rejected.
Jul 23 08:14:52: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8456) is rejected.
Jul 23 08:15:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8457) is rejected.
Jul 23 08:15:43: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8458) is rejected.
Jul 23 08:16:29: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8459) is rejected.
Jul 23 08:17:16: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8460) is rejected.
Jul 23 08:21:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8461) is rejected.
Jul 23 08:21:37: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8462) is rejected.
Jul 23 08:24:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8463) is rejected.
Jul 23 08:24:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8464) is rejected.
Jul 23 08:27:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8465) is rejected.
Jul 23 08:27:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8466) is rejected.
Jul 23 08:28:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8467) is rejected.
Jul 23 08:28:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8468) is rejected.
Jul 23 08:29:43: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8469) is rejected.
Jul 23 08:37:11: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8470) is rejected.
Jul 23 08:37:26: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8471) is rejected.
Jul 23 08:37:37: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8472) is rejected.
Jul 23 08:38:08: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8473) is rejected.
Jul 23 08:38:18: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8474) is rejected.
Jul 23 08:38:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8475) is rejected.
Jul 23 08:39:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8476) is rejected.
Jul 23 08:43:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=8477) is rejected.
Jul 23 08:43:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=8478) is rejected.
Jul 23 08:44:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8479) is rejected.
Jul 23 08:44:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8480) is rejected.
Jul 23 08:44:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8481) is rejected.
Jul 23 08:44:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8482) is rejected.
Jul 23 08:44:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8483) is rejected.
Jul 23 08:45:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8484) is rejected.
Jul 23 08:45:57: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8485) is rejected.
Jul 23 08:46:26: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8486) is rejected.
Jul 23 08:46:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8487) is rejected.
Jul 23 08:46:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8488) is rejected.
Jul 23 08:47:24: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8489) is rejected.
Jul 23 08:48:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8490) is rejected.
Jul 23 08:48:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8491) is rejected.
Jul 23 08:48:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8492) is rejected.
Jul 23 08:48:57: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8493) is rejected.
Jul 23 08:49:11: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8494) is rejected.
Jul 23 08:49:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8495) is rejected.
.Jul 23 08:49:49: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8496) is rejected.
.Jul 23 08:50:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8497) is rejected.
Jul 23 08:50:28: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8498) is rejected.
Jul 23 08:50:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8499) is rejected.
Jul 23 08:58:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8500) is rejected.
Jul 23 08:58:35: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8501) is rejected.
Jul 23 08:59:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8502) is rejected.
Jul 23 09:03:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8503) is rejected.
Jul 23 09:03:43: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8504) is rejected.
Jul 23 09:04:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8505) is rejected.
Jul 23 09:04:15: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8506) is rejected.
Jul 23 09:04:57: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8507) is rejected.
Jul 23 09:05:15: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8508) is rejected.
Jul 23 09:05:29: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8509) is rejected.
Jul 23 09:06:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8510) is rejected.
Jul 23 09:06:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8511) is rejected.
Jul 23 09:06:52: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8512) is rejected.
Jul 23 09:07:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8513) is rejected.
Jul 23 09:07:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8514) is rejected.
Jul 23 09:07:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8515) is rejected.
Jul 23 09:08:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8516) is rejected.
Jul 23 09:08:08: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8517) is rejected.
Jul 23 09:08:33: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8518) is rejected.
Jul 23 09:08:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8519) is rejected.
Jul 23 09:09:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8520) is rejected.
Jul 23 09:09:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8521) is rejected.
Jul 23 09:10:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8522) is rejected.
Jul 23 09:10:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8523) is rejected.
Jul 23 09:10:26: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8524) is rejected.
Jul 23 09:10:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8525) is rejected.
Jul 23 09:11:21: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8526) is rejected.
Jul 23 09:11:35: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8527) is rejected.
Jul 23 09:12:33: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8528) is rejected.
Jul 23 09:12:54: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8529) is rejected.
Jul 23 09:13:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8530) is rejected.
Jul 23 09:13:55: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8531) is rejected.
Jul 23 09:13:58: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8532) is rejected.
Jul 23 09:14:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8533) is rejected.
Jul 23 09:14:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8534) is rejected.
Jul 23 09:14:26: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8535) is rejected.
Call (callID=8536) is rejected.
Jul 23 09:14:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8537) is rejected.
Jul 23 09:14:50: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8538) is rejected.
Jul 23 09:14:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8539) is rejected.
Jul 23 09:15:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8540) is rejected.
Jul 23 09:15:32: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8541) is rejected.
Jul 23 09:15:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8542) is rejected.
Jul 23 09:15:43: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8543) is rejected.
Jul 23 09:16:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8544) is rejected.
Jul 23 09:17:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8545) is rejected.
Jul 23 09:17:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8546) is rejected.
Jul 23 09:17:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8547) is rejected.
Jul 23 09:17:55: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8548) is rejected.
Jul 23 09:18:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8549) is rejected.
Jul 23 09:18:28: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8550) is rejected.
Jul 23 09:19:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8551) is rejected.
Jul 23 09:19:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8552) is rejected.
Jul 23 09:19:24: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8553) is rejected.
Jul 23 09:19:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8554) is rejected.
Jul 23 09:20:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8555) is rejected.
Jul 23 09:20:25: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8556) is rejected.
Jul 23 09:20:29: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8557) is rejected.
Jul 23 09:21:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8558) is rejected.
Jul 23 09:21:31: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8559) is rejected.
Jul 23 09:23:55: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8560) is rejected.
Jul 23 09:24:17: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8561) is rejected.
Jul 23 09:24:35: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8562) is rejected.
Jul 23 09:25:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8563) is rejected.
Jul 23 09:26:18: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8564) is rejected.
Jul 23 09:27:31: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8565) is rejected.
Jul 23 09:28:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8566) is rejected.
Jul 23 09:28:33: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8567) is rejected.
Jul 23 09:30:54: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8568) is rejected.
Jul 23 09:31:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8569) is rejected.
Jul 23 09:31:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8570) is rejected.
Jul 23 09:31:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8571) is rejected.
Jul 23 09:32:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8572) is rejected.
Jul 23 09:32:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8573) is rejected.
Jul 23 09:32:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8574) is rejected.
Jul 23 09:33:31: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8575) is rejected.
Jul 23 09:34:16: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8576) is rejected.
Jul 23 09:34:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8577) is rejected.
Jul 23 09:36:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8578) is rejected.
Jul 23 09:36:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8579) is rejected.
.Jul 23 09:37:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8580) is rejected.
.Jul 23 09:37:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8581) is rejected.
Jul 23 09:40:00: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=8582) is rejected.
Jul 23 09:43:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8583) is rejected.
Jul 23 09:45:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8584) is rejected.
Jul 23 09:45:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8585) is rejected.
Jul 23 09:46:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8586) is rejected.
Jul 23 09:46:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8587) is rejected.
Jul 23 09:56:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8588) is rejected.
Jul 23 09:56:57: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8589) is rejected.
Jul 23 09:57:32: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8590) is rejected.
Jul 23 09:57:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8591) is rejected.
Jul 23 09:58:10: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8592) is rejected.
Jul 23 10:07:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8593) is rejected.
Jul 23 10:40:25: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=8594) is rejected.
Jul 23 10:41:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8595) is rejected.
Jul 23 10:42:21: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8596) is rejected.
Jul 23 10:46:36: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8597) is rejected.
Jul 23 10:46:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8598) is rejected.
Jul 23 10:47:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=8599) is rejected.
Jul 25 09:38:50: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=9552) is rejected.
Jul 25 09:39:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=9553) is rejected.
Jul 25 09:39:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=9554) is rejected.
Jul 25 09:39:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=9555) is rejected.
Jul 25 09:39:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=9556) is rejected.
Jul 25 13:17:12: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=10061) is rejected.
Jul 25 13:17:18: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=10062) is rejected.
Jul 25 13:18:28: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=10069) is rejected.
Jul 25 13:19:28: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=10070) is rejected.
Jul 25 13:21:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=10075) is rejected.
Call (callID=10076) is rejected.
Jul 25 13:22:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=10077) is rejected.
Jul 25 13:22:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=10078) is rejected.
Jul 25 13:22:50: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=10079) is rejected.
Jul 27 21:07:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=13504) is rejected.
Jul 30 06:19:50: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16229) is rejected.
Jul 30 06:20:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16230) is rejected.
Jul 30 06:39:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16231) is rejected.
Jul 30 06:39:32: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16232) is rejected.
Jul 30 06:41:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16233) is rejected.
Jul 30 06:46:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16234) is rejected.
Jul 30 06:46:15: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16235) is rejected.
Jul 30 06:46:29: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16236) is rejected.
Jul 30 06:46:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16237) is rejected.
Jul 30 06:47:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16238) is rejected.
Jul 30 06:47:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16239) is rejected.
Jul 30 06:47:37: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16240) is rejected.
Jul 30 06:48:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16241) is rejected.
Jul 30 06:49:06: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16242) is rejected.
Jul 30 06:49:51: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16243) is rejected.
Jul 30 06:50:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16244) is rejected.
Jul 30 06:52:36: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16245) is rejected.
Jul 30 06:53:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16246) is rejected.
Jul 30 06:53:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16247) is rejected.
Jul 30 06:54:11: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16248) is rejected.
Jul 30 06:54:37: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16249) is rejected.
Jul 30 06:54:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16250) is rejected.
Jul 30 06:54:51: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16251) is rejected.
Jul 30 06:54:57: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16252) is rejected.
Jul 30 06:54:58: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16253) is rejected.
Jul 30 06:55:12: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16254) is rejected.
Jul 30 06:55:17: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16255) is rejected.
Jul 30 06:55:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16256) is rejected.
Jul 30 06:55:55: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16257) is rejected.
Jul 30 06:56:49: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16258) is rejected.
Jul 30 06:57:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16259) is rejected.
Jul 30 06:58:11: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16260) is rejected.
Jul 30 06:58:24: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16261) is rejected.
Jul 30 06:58:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16262) is rejected.
Jul 30 07:02:08: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16263) is rejected.
Jul 30 07:03:32: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16264) is rejected.
Jul 30 07:04:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16265) is rejected.
Jul 30 07:06:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16266) is rejected.
Jul 30 07:08:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16267) is rejected.
Jul 30 07:09:50: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16268) is rejected.
Jul 30 07:10:12: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16269) is rejected.
Jul 30 07:10:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16270) is rejected.
Jul 30 07:10:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16271) is rejected.
Jul 30 07:11:16: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16272) is rejected.
Jul 30 07:14:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16273) is rejected.
Jul 30 07:18:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16274) is rejected.
Jul 30 07:19:54: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16275) is rejected.
Jul 30 07:20:08: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16276) is rejected.
Jul 30 07:20:51: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16277) is rejected.
Jul 30 07:21:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16278) is rejected.
Jul 30 07:21:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16279) is rejected.
Jul 30 07:21:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16280) is rejected.
Jul 30 07:22:16: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16281) is rejected.
Jul 30 07:22:25: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16282) is rejected.
Call (callID=16283) is rejected.
Jul 30 07:22:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16284) is rejected.
Jul 30 07:23:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16285) is rejected.
Jul 30 07:23:08: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16286) is rejected.
Jul 30 07:23:21: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16287) is rejected.
Jul 30 07:23:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16288) is rejected.
Jul 30 07:23:33: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16289) is rejected.
Jul 30 07:23:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16290) is rejected.
Jul 30 07:23:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16291) is rejected.
Jul 30 07:24:06: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16292) is rejected.
Jul 30 07:24:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16293) is rejected.
Jul 30 07:24:21: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16294) is rejected.
Jul 30 07:24:43: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16295) is rejected.
Jul 30 07:25:21: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16296) is rejected.
Jul 30 07:25:52: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16297) is rejected.
Jul 30 07:27:21: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16298) is rejected.
Jul 30 07:27:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16299) is rejected.
Jul 30 07:33:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16300) is rejected.
Jul 30 07:37:15: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16301) is rejected.
Jul 30 07:38:20: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16302) is rejected.
Jul 30 07:39:08: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16303) is rejected.
Jul 30 07:40:36: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16304) is rejected.
Jul 30 07:41:18: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16305) is rejected.
Jul 30 07:41:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16306) is rejected.
Jul 30 07:41:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16307) is rejected.
Jul 30 07:42:06: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16308) is rejected.
Jul 30 07:44:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16309) is rejected.
Jul 30 07:45:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16310) is rejected.
Jul 30 07:45:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16311) is rejected.
Jul 30 07:48:29: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16312) is rejected.
Jul 30 07:50:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16313) is rejected.
Jul 30 07:51:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16314) is rejected.
Jul 30 07:51:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16315) is rejected.
Jul 30 07:51:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16316) is rejected.
Jul 30 07:52:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16317) is rejected.
Jul 30 07:52:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16318) is rejected.
Jul 30 07:52:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16319) is rejected.
Jul 30 07:52:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16320) is rejected.
Jul 30 07:53:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16321) is rejected.
Jul 30 07:53:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16322) is rejected.
Jul 30 07:54:17: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16323) is rejected.
Jul 30 07:56:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16324) is rejected.
Jul 30 07:59:17: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16325) is rejected.
Jul 30 08:01:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16326) is rejected.
Jul 30 08:05:10: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16327) is rejected.
Jul 30 08:05:43: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16328) is rejected.
Jul 30 08:06:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16329) is rejected.
Jul 30 08:06:42: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16330) is rejected.
Jul 30 08:07:12: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16331) is rejected.
Jul 30 08:09:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16332) is rejected.
Jul 30 08:10:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16333) is rejected.
Jul 30 08:10:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16334) is rejected.
Jul 30 08:11:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16335) is rejected.
Jul 30 08:13:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16336) is rejected.
Jul 30 08:13:26: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16337) is rejected.
Jul 30 08:18:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16338) is rejected.
Jul 30 08:20:10: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16339) is rejected.
Jul 30 08:20:35: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16340) is rejected.
Jul 30 08:21:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16341) is rejected.
Jul 30 08:21:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16342) is rejected.
Jul 30 08:27:54: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16343) is rejected.
Jul 30 08:28:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16344) is rejected.
Jul 30 08:29:09: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16345) is rejected.
Jul 30 08:30:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16346) is rejected.
Jul 30 08:31:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16347) is rejected.
Jul 30 08:36:15: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16348) is rejected.
Jul 30 08:36:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16349) is rejected.
Jul 30 08:37:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16350) is rejected.
Jul 30 08:46:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16351) is rejected.
Jul 30 08:46:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16352) is rejected.
Jul 30 08:46:54: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16353) is rejected.
Jul 30 08:46:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16354) is rejected.
Jul 30 08:46:57: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16355) is rejected.
Jul 30 08:46:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16356) is rejected.
Jul 30 08:47:00: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16357) is rejected.
Jul 30 08:47:03: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16358) is rejected.
Jul 30 08:47:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16359) is rejected.
Jul 30 08:47:06: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16360) is rejected.
Jul 30 08:47:18: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16361) is rejected.
Jul 30 08:47:36: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16362) is rejected.
Jul 30 08:50:33: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16369) is rejected.
Jul 30 08:50:55: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16370) is rejected.
Jul 30 08:55:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16371) is rejected.
Jul 30 08:56:30: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16372) is rejected.
Jul 30 08:57:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16373) is rejected.
Jul 30 08:57:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16374) is rejected.
Jul 30 08:57:45: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16375) is rejected.
Jul 30 08:58:00: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16376) is rejected.
Jul 30 08:58:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16377) is rejected.
Jul 30 08:58:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16378) is rejected.
Jul 30 08:58:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16379) is rejected.
Jul 30 08:58:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16380) is rejected.
Jul 30 08:59:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16381) is rejected.
Jul 30 08:59:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16382) is rejected.
Jul 30 08:59:28: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16383) is rejected.
Jul 30 09:00:00: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16384) is rejected.
Jul 30 09:00:01: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16385) is rejected.
Jul 30 09:00:15: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16386) is rejected.
Jul 30 09:00:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16387) is rejected.
Jul 30 09:00:30: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16388) is rejected.
Jul 30 09:02:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16389) is rejected.
Jul 30 09:02:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16390) is rejected.
Jul 30 09:02:33: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16391) is rejected.
Jul 30 09:03:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16392) is rejected.
Jul 30 09:03:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16393) is rejected.
Jul 30 09:06:28: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16394) is rejected.
Jul 30 09:06:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16395) is rejected.
Jul 30 09:07:16: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16396) is rejected.
Jul 30 09:12:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16397) is rejected.
Jul 30 09:13:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16398) is rejected.
Jul 30 09:16:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16399) is rejected.
Jul 30 09:19:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16400) is rejected.
Jul 30 09:20:04: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16401) is rejected.
Jul 30 09:24:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16404) is rejected.
Jul 30 09:24:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16405) is rejected.
Jul 30 09:25:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16406) is rejected.
Jul 30 09:26:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16407) is rejected.
Jul 30 09:27:00: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16408) is rejected.
Jul 30 09:27:59: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16409) is rejected.
Jul 30 09:28:25: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16410) is rejected.
Jul 30 09:29:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16411) is rejected.
Jul 30 09:30:02: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16412) is rejected.
Jul 30 09:30:25: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16413) is rejected.
Jul 30 09:30:44: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16414) is rejected.
Jul 30 09:31:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16415) is rejected.
Jul 30 09:33:19: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16416) is rejected.
Jul 30 09:34:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16417) is rejected.
Jul 30 09:34:48: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16418) is rejected.
Jul 30 09:35:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16419) is rejected.
Jul 30 09:36:07: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16420) is rejected.
Jul 30 09:36:53: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16421) is rejected.
Jul 30 09:37:13: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16422) is rejected.
Jul 30 09:37:32: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16423) is rejected.
Jul 30 09:41:10: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16424) is rejected.
Jul 30 09:42:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16425) is rejected.
Jul 30 09:43:30: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16426) is rejected.
Jul 30 09:47:03: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16427) is rejected.
Jul 30 09:47:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16428) is rejected.
Jul 30 09:50:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16429) is rejected.
Jul 30 09:52:38: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16430) is rejected.
Jul 30 09:52:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16431) is rejected.
Jul 30 10:06:30: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16432) is rejected.
Jul 30 10:07:47: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16433) is rejected.
Jul 30 10:09:40: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16434) is rejected.
Jul 30 10:10:39: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16435) is rejected.
Jul 30 11:29:31: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16436) is rejected.
Jul 30 11:31:12: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=16437) is rejected.
Jul 30 11:31:34: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16438) is rejected.
Jul 30 11:32:22: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16439) is rejected.
Jul 30 11:33:14: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16440) is rejected.
Jul 30 11:33:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16441) is rejected.
Jul 30 11:33:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16442) is rejected.
Jul 30 11:37:23: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16443) is rejected.
Jul 30 11:51:37: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (98/100).
Call (callID=16444) is rejected.
Jul 30 21:31:46: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16505) is rejected.
Jul 30 21:32:31: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16506) is rejected.
Jul 30 21:34:06: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16509) is rejected.
Jul 30 21:34:27: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16510) is rejected.
Jul 30 21:34:56: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16511) is rejected.
Jul 30 21:36:05: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16512) is rejected.
Jul 30 21:37:41: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=16513) is rejected.
Is this issue resolved?
Create
Recognize Your Peers
Content for Community-Ad
