IVR TCL question, please help
Alex55555
Beginner
Beginner
  1. I make a call to number ZZZ;
  2. I hear welcome.au prompt;
  3. I dial valid extension and see call is transferred to that extension;
  4. I see incoming call on the extension number;
  5. I decline the call on the extension called number;
  6. Then I see that my call is not disconnected (as it supposed to be) but it is then transferred to operator number 1330. Why? I want it to be disconnected.
How to disconnect the call after decline on called number?
Here my config:
Incoming dial-peer:
dial-peer voice 5 voip
description Optimum SIP trunk Incoming
translation-profile incoming SIPInbound
service ivr_optimum
session protocol sipv2
incoming called-number ZZZ
voice-class sip bind control source-interface FastEthernet0/1
voice-class sip bind media source-interface FastEthernet0/1
dtmf-relay rtp-nte sip-notify
codec g711ulaw
Application:
application
service ivr_optimum flash:optimum/optimum.tcl
  paramspace english language en
  paramspace english index 0
  param aa-pilot ZZZ
  param operator 1330
  paramspace english location flash:optimum/
Files on router flash:
voice02#sh flash: | i optimum/
8185 Nov 6 2020 16:17:18 +03:00 optimum/optimum.tcl
00523 Nov 6 2020 16:18:46 +03:00 optimum/en_welcome.au
TCL script in the attachment (I found it in the Internet and changed only name not itself).
Besides this problem all is working well.
Alex55555
Beginner
Beginner
# Script Locked by: khom
# Script Version: 2.0.2.0
# Script Name: its_CISCO
# Script Lock Date: Wed Jul 2 09:22:04 2003
# November 27, 2001, Satish Ananthanarayana (sanantha@cisco.com)
# Modification History:
# May 20, 2008, Jasmine Kalaiselvan (jkalaise@cisco.com)
# Modified the script to do leg setup and then handovers the call
# to Default IOS app. DDTS for this change: CSCsq35953 CSCsl08148
# Copyright (c) 2001 by cisco Systems, Inc.
# All rights reserved.
# Description:
# This is a TCL IVR script for the IOS Telephony Service and
# Call Manager (CM) offload scenario. The IVR script plays a
# welcome prompt to the user and prompts the user to enter a
# destination number when the user dials the auto-attendant number
# (aa-pilot configured in the CLI). The script collects the digits that
# the user has entered and hands the call to the enhanced session
# application (named Default). The session application
# returns once there is a disconnect (if the call is established)
# or if a call setup problem occurs.
# The operator support is also included, if the user does not dial
# any number or enters "0" the user will be transfered to an operator
# (if operator number is configured in the CLI). If the user enters
# an invalid number, the user will be prompted again to re-enter
# the number for upto 3 times before disconnecting the call.
proc init { } {
global param1
global selectCnt
global callInfo
global legConnected
global maxExtensionLen
set param1(interruptPrompt) true
set param1(abortKey) *
set param1(terminationKey) #
set selectCnt 0
set legConnected false
proc init_ConfigVars { } {
global destination
global aaPilot
global oprtr
# aa-pilot is the IVR number configured on the gateway to be used by the customer
# operator is the operator number for assisted calling
if [infotag get cfg_avpair_exists aa-pilot] {
set aaPilot [string trim [infotag get cfg_avpair aa-pilot]]
} else {
set aaPilot "NONE"
if [infotag get cfg_avpair_exists operator] {
set oprtr [string trim [infotag get cfg_avpair operator]]
} else {
set oprtr "NONE"
if [infotag get cfg_avpair_exists max-extension-length] {
set maxExtensionLen [string trim [infotag get cfg_avpair max-extension-length]]
if { $maxExtensionLen < 0 } {
call close
} else {
set maxExtensionLen 5
proc init_perCallVars { } {
puts "\nproc init_perCallvars"
global ani
global digit_enabled
global fcnt
global retrycnt
global dnis
set fcnt 0
set retrycnt 6
set ani ""
set dnis ""
set digit_enabled "FALSE"
set ani [infotag get leg_ani]
puts "\nANI $ani"
set dnis [infotag get leg_dnis]
puts "\nDNIS $dnis"
proc act_Setup { } {
global param1
global selectCnt
global dest
global beep
global callInfo
global dnis
global fcnt
global aaPilot
global oprtr
global busyPrompt
global legConnected
puts "proc act_Setup"
set busyPrompt _dest_unreachable.au
set beep 0
init_perCallVars
infotag set med_language 1
if { ($dnis == "") || ($dnis == $aaPilot) } {
leg setupack leg_incoming
leg proceeding leg_incoming
leg connect leg_incoming
set legConnected true
puts "\nNo DNIS\n"
set param1(dialPlan) true
leg collectdigits leg_incoming param1
media play leg_incoming _welcome.au %s1000 _enter_dest.au
} else {
set fcnt 6
#handoff callappl leg_incoming default "DESTINATION=$dnis"
set callInfo(alertTime) 30
leg setup $dnis callInfo leg_incoming
fsm setstate HANDOFF
proc act_GotDest { } {
global dest
global destExtLen
global callInfo
global oprtr
global busyPrompt
puts "\n proc act_GotDest"
set status [infotag get evt_status]
puts "\n STATUS: $status"
puts "\n MAXEXTENSION: $maxExtensionLen"
if { ($status == "cd_004") } {
set dest [infotag get evt_dcdigits]
set destExtLen [string length $dest]
puts "\n DESTLEN: $destExtLen"
set extLength [expr $maxExtensionLen - $destExtLen]
if { $dest == "0" } {
set dest $oprtr
puts "\n extLength: $extLength"
#handoff callappl leg_incoming default "DESTINATION=$dest"
if {($maxExtensionLen > 0) && ($extLength >= 0)} {
leg setup $dest callInfo leg_incoming
} else {
set busyPrompt _bacd_invalidoption.au
act_Select
} elseif { ($status == "cd_001") || ($status == "cd_002") } {
set dest $oprtr
} else {
if { $status == "cd_006" } {
puts "\nCall [infotag get con_all] got event $status collecting destination"
set dest $oprtr
} else {
act_Select
proc act_CallSetupDone { } {
global busyPrompt
global legConnected
if { $status == "ls_000" } {
puts "\n Connection success"
handoff appl leg_all default
act_Cleanup
} else {
if { $legConnected == "false" } {
puts "\n Call failed. Play prompt and collect digit"
if { ($status == "ls_007") } {
set busyPrompt _dest_busy.au
act_Select
proc act_Select { } {
global destination
global promptFlag2
global destBusy
global param1
global fcnt
global retrycnt
global busyPrompt
puts "\n proc act_Select"
set promptFlag2 0
set param1(dialPlanTerm) true
if { $fcnt < $retrycnt } {
media play leg_incoming $busyPrompt %s500 _reenter_dest.au
incr fcnt
fsm setstate GETDEST
} else {
act_DestBusy
proc act_DestBusy { } {
puts "\n proc act_DestBusy"
media play leg_incoming _disconnect.au
fsm setstate CALLDISCONNECT
proc act_Cleanup { } {
call close
requiredversion 2.0
init
init_ConfigVars
# State Machine
set fsm(any_state,ev_disconnected) "act_Cleanup same_state"
set fsm(any_state,ev_disconnect_done) "act_Cleanup same_state"
set fsm(CALL_INIT,ev_setup_indication) "act_Setup GETDEST"
set fsm(GETDEST,ev_collectdigits_done) "act_GotDest HANDOFF"
#set fsm(HANDOFF,ev_returned) "act_CallSetupDone CONTINUE"
set fsm(HANDOFF,ev_setup_done) "act_CallSetupDone CONTINUE"
set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup same_state"
fsm define fsm CALL_INIT
# Script Approval Signature: C/775c
Alex55555
Beginner
Beginner
any idias?
still need it
thank for share
IONIA
https://ionia.com.vn/6-cach-lua-chon-may-loc-nuoc-ion-kiem-tot-nhat
Alex55555
Beginner
Beginner
what the use of the link?
Recognize Your Peers
