10-07-2014 12:57 AM - edited 03-17-2019 12:27 AM
Hello!
I've got CUBE on 2901 with IOS c2900-universalk9_npe-mz.SPA.154-3.M.bin.
SIP provider uses g711 alaw codec for SIP trunk.
I need to transcode incoming calls from g711a to g711u before playing IVR script.
I've configured transcoding profile on CUBE(in telephony-service, also I can use LTI as I know), but how can I enable transcoding on CUBE, so that it works in SRST mode too?
How many dial-peers do I need for solving this problem?
One incoming from provider with hard-coded g711a and another for IVR with g711u?
I know that transcoding turns on when one call leg is in one codec and second call leg is in another codec. How can I terminate incoming call from one to another dial-peer?
I tried with voice translation rules, but it doesn't work, router chooses incorrect DP or don't chooses outgoing call leg at all....
Sample of config:
application
service test flash:/ivrfax.vxml
voice translation-rule 3
rule 1 /308042/ /555/
voice translation-profile 308042_income
translate called 3
dial-peer voice 1 voip
description To_CUCM
destination-pattern [1-8]...
session protocol sipv2
session target ipv4:10.128.2.2
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 2 voip
description To_CUCM
session target ipv4:10.128.2.3
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 308042 voip
description ---Outgoing to SIP 308042---
translation-profile outgoing 308042
destination-pattern 9T
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 30804242 voip
description from_Provider_incoming
translation-profile incoming 308042_income
incoming called-number 308042
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 555 voip
description IVR
service test
incoming called-number 555
dtmf-relay rtp-nte
codec g711ulaw
no vad
Thanks for any help or information!
10-07-2014 02:52 AM
it should work in SRST
What is your call flow and what is your current issue apart from xcoder
10-08-2014 05:52 AM
My issue is problem with xcoding of incoming calls to IVR. I don't understand how can I do it using dial-peers or voice-translation rules. In debug ccsip mess it always chooses dial-peers 1 or (wrong) or there is not any outgoing DP when I change some settings in config. What I am missing for?
10-21-2014 06:42 AM
So, can anybody help me?
I tried to only one one incoming dila-peer, but I don't hear anything in my audiofile via call, call establishes in g711a codec.
https://supportforums.cisco.com/discussion/11978696/transcode-incoming-calls-and-ivr
10-07-2014 06:17 AM
Have you reviewed this for dial-peer matching understanding:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Where is the call going to connect under SRST, will the IVR still be available?
You can use telephony-service (CME) and register xcoders to it, keep in mind that to transcode between u-law to a-law you will require universal transcoders and not traditional transcoders, so review config for universal transcoders.
Chris
10-08-2014 05:45 AM
Yes, I read this document.
I've created ccm group, sccp local interface, dspfarm profile, and registered it to telephony-service. It's ok.
Yes, IVR still be availible under SRST, it runs as vxml script on router flash.
I configured router for inbound/outbound calls in g711a, and it works fine. But when using IVR with .wav file in g711u codec I've got a problem. I decided to use translation-profile on incoming dial-peer, from incoming number to internal IVR number, but it doesn't work.
I attached config of xcoder, dial-peers and translation rules.
In normal mode (without IVR) I receive calls in dial-peer voice 30804242 voip and after it translate them to dial-peers 1 or 2 to CUCM phones.
