307
Highlighted
Beginner
Jabber cann't make call
i have a issue with Cisco Jabber Call, it not able to make  calls as it is giving ring tone but calls are not getting connected.
3 REPLIES 3
Highlighted
Rising star
Hi siwar,
Are you behind a firewall or do you have any antivirus enabled?
Try disabling anything that could block the Jabber's traffic, just for testing.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Highlighted
the problem with one or two users is calls in house, it worked before perfectly, the only thing that has changed is upgrade cisco jabber to version 12.1.
no problem with firwall because it works for other users
Highlighted
VIP Collaborator
Try to check the routing between the 2 endpoints (Jabber and the other side).
If you know it, try to ping from the PC that you have Jabber the other end to check if you get a reply.
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Content for Community-Ad
