Hello team,
Some configurations (enable/disable features) for Jabber client, can not be done through either CUPS or CUCM GUI, that is why we need jabber-config.xml.
But if I simply deploy a Jabber client without Jabber-config.xml, how can I tell the features/functions, which are supposed to be enabled/disabled only through jabber-config.xml, are actually enabled or disabled by default?
