05-06-2019 06:15 AM
Hi experts, one of our clients had requirement to perform contact search using Department/Title, we manage to get it work using the parameter "PredictiveSearchFilter" in Jabber config file. The deployment uses MS Active directory. The Predictive search filters does not seem to work over MRA. Are we missing any config or is there a way to make it work? Thnx
05-06-2019 09:27 PM
I think its not supported over MRA. Please check the below link (under page 15 Known Unsupported Client and Endpoint Features )
Please rate if it is helpful...
05-07-2019 01:19 AM
Unfortunately, this is not -currently- supported over MRA as you may check below:
George
