439
Highlighted
Jabber download for CUCM
Installing our first Jabber on IM&P Version 10.5 and expected that Jabber might be a plug in that you download from the cluster.  Not the case, or I could not find it.   Downloading it from CISCO however, I get a version that seems to want an email address and offers no option to configure the server?   So were do you get Jabber if you are just planning to use it internally on CUCM and not through a cloud service?
6 REPLIES 6
Highlighted
Refer below:
Refer below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_5/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber_chapter_0100.html#JABW_RF_AA52487D_00
Deepak
Highlighted
Hall of Fame Cisco Employee
Newer versions are meant to
Newer versions are meant to be used with SRV records so you configure those in your network, and once the user enters their JID, it will automatically find the right servers to use.
java
if this helps, please rate
Highlighted
what i note is that the
what i note is that the windows jabber version I downloaded asks for the users email address, not their Jabber ID?  Can I configure the server record in ios?  I am using the voice gateway to do network services like NTP and DNS?
Highlighted
They're both formatted the
They're both formatted the same way, and internally, the users can use their email address, assuming it does not match their JID. It will automatically change the email to their JID
java
Highlighted
That will depend on what
That will depend on what versions are used, the Jabber documentation has a whole chapter dedicated to service discovery which covers this, if you haven't, I suggest you review that documentation.
java
Highlighted
Jamie does the server record
Jamie does the server record point to the CUCM or the IM&P?  I am guessing registration to CUCM.
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
