02-11-2016
04:02 AM
- last edited on
03-25-2019
08:38 PM
by
ciscomoderator
Hi ,
I have created a Local User account in the CM , assigned a Jabber for Iphone , but on the Iphone , when I try to log in with his local account I get "wrong user/password"
If I use My AD windows account then I can login.
when configuring Jabber it ask a username@domain.com , that I have with my AD account , but don't know for the local account
Is it possible ?
quite similar to this one , but on Jabber for Iphone
Alban
Solved! Go to Solution.
02-12-2016 07:09 AM
You should use the same domain as your server is in, can you login with that user to the self care portal??
You can also try to manually configure your CUCM server, and try with just the username/pwd
02-12-2016 07:09 AM
02-12-2016 07:11 AM
I had the confirmation with the TAC , use the same domain even if it's not an AD account , and it works.
thanks
