04-11-2019 09:13 PM
Hi, is there any one here successfully setup Jabber for Mac with Certificate-based Authentication SSO (ADFS 3.0)?
In my Lab, I have setup CUCM 11.5 & Unity Connection 11.5 with SSO/ADFS3.0 Integration. Jabber for Windows, Jabber for Mac, Jabber for iPhone, & Jabber for Android can login & register (to CUCM & Unity Connection) successfully. WIA or Form-based login is totally OK.
I try to enhance the setup, to support Certificate-based Authentication. The configuration enhancement is mainly at ADFS side, but also include CUCM & Unity Connection Enterprise Parameter - SSO Login behavior > Native Safari Browser. After reconfiguration, all Jabber client, except J4Mac, can successfully login by Client Certificate.
For Jabber for Mac, it shows a blank page at the Jabber Client when it is trying to do Certificate authentication. It is very similar to the behavior of iOS client before I set the Enterprise Parameter (of CUCM & Unity Connection), "SSO Login behavior for iOS" parameter into "use native browser". But I cannot find any way to force the Jabber for Mac to "use native browser".
FYI, the Client Certificate is correct. I have install it to my Keychain, and the Safari can successfully login to CUCM web portal with the Cert.
Is there any recommendation here?
04-11-2019 10:52 PM
Is this integrated with azure adfs?
04-11-2019 10:57 PM
Hi Dennis,
The Idp Server is a Windows 2012 R2 Server, running ADFS 3.0.
The AD Server itself is a Windows 2008.
WIA or Form-based SSO is totally OK for all Jabber client.
Certificate-based SSO is OK for all client except for Jabber for Mac.
07-03-2019 08:31 AM
Did you ever solve this? We have the same situation.
