Jabber for windows configuration required in CUCM 8.6 and CUPS
Vivek Batra
Friends,
I'm running with CUCM 8.6 and CUPS (not in use as of now) with very few 79xx series IP phones.
Now I want to use Jabber for Windows however whatever information I'm getting is for CUCM 9.1 or above where most of the steps are not matching with parameters available in CUCM 8.6.
Can you please redirect me to useful document having information about Jabber for Windows configuration in CUCM 8.6?
Vivek
Jaime Valencia
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_1/JABW_BK_E4CC9599_00_environment-configuration-guide/JABW_BK_E4CC9599_00_environment-configuration-guide_chapter_01.html
As to the other post, just copy the URL and remove partner/
java
if this helps, please rate
Hi Jaime,
Thank you very much for the information. I will try to configure by applying the steps and in case of any issue, will revert back.
Vivek
