06-20-2018 01:45 AM - edited 03-17-2019 01:03 PM
Hi Experts, i have trouble logging in with Jabber after CUCM IP change! Where does the Jabber pull the tftp info from ? seems its getting the old IP. Thanks
Solved! Go to Solution.
06-20-2018 02:08 AM
On IMP check below things
- Go to System >> Presence Topology and see if there is any error or not
- Go to Presence >> Gateways >> Check if the IP Address is Old or new one
- Go to Application >> Client Settings >> Check the details of the TFTP servers and verify if it is old or new
- Check the CCMCIP profile config as well under Application >> Client Settings
##On CUCM check if the Service profile has got correct IPs of new CUCM nodes for CTI.
Kindly rate all helpful posts !!!
Abhay
06-20-2018 02:08 AM
Abhay
