Jabber iphone in CME ver 8.6 problem
Yazen Alaa
Dear All
I have Jabber Iphone and CME ver 8.6 , the Iphone jabber it is regsitered in CME but when call outside,  after 30 sec to one minute it will disconnect  ?
anybody face this problem ? how to solve it ?
thanks and regards
7 Replies 7
paolo bevilacqua
Configure sip bind interface for the interface to which you are registering.
Hi Paolo
it is already configured
Yazen Alaa
Any Reply
thanks
this is the configuration that i have
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  bind control source-interface Vlan100
  bind media source-interface Vlan100
  registrar server expires max 600 min 60
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 56
max-pool 14
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
authenticate register
hold-alert
voicemail 32
tftp-path flash:
create profile sync 0007538850446524
voice register dn  1
number 27
name Mishaal Al-Rayes
no-reg
label Mishaal
voice register dn  2
number 28
name Dalal Al-Rayes
no-reg
label Dalal
voice register dn  3
number 00
name Master Bedroom Mr.Mishaal
no-reg
voice register dn  4
number 02
name Mdm.Dalal Changing Room
no-reg
voice register dn  5
number 12
name GF Kitchen
no-reg
voice register dn  6
number 25
name Services
no-reg
voice register pool  1
registration-timer max 720 min 660
id mac C09F.4241.B12D
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username mishaal password 1234567
codec g711ulaw
voice register pool  2
id mac C09F.4271.73EA
number 1 dn 2
dtmf-relay rtp-nte
username dalal password 1234567
codec g711ulaw
voice register pool  3
id mac 0026.CB0E.6D61
number 3 dn 3
dtmf-relay rtp-nte
username 00 password ext00
codec g711ulaw
no vad
voice register pool  4
id mac 0026.CB0E.6E03
number 4 dn 4
dtmf-relay rtp-nte
username 02 password ext02
codec g711ulaw
no vad
voice register pool  5
id mac 0026.CB0E.6D22
number 5 dn 5
dtmf-relay rtp-nte
username 12 password ext12
codec g711ulaw
no vad
voice register pool  6
id mac 0026.CB0E.6E77
number 6 dn 6
dtmf-relay rtp-nte
username 25 password ext25
codec g711ulaw
no vad
voice hunt-group 1 parallel
list 04,00,11,14,20,12,22,23,18,19
timeout 16
pilot 40
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2222
rule 1 /^910./ //
rule 2 /^912./ //
rule 4 /^913./ //
rule 5 /^914./ //
rule 6 /^915[4-6]\(.*\)/ //
rule 7 /^906........./ //
rule 8 /^908........./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC540W-FXO-K9 sn FHK143074FS
archive
log config
  logging enable
  logging size 600
  hidekeys
username cisco privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 105 in
ip access-group 106 out
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
switchport access vlan 100
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
shutdown
encryption vlan 1 mode ciphers tkip
encryption vlan 100 mode ciphers tkip
ssid Mishaal Al-Rayes
ssid Mishaal Al-Rayes-Voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 10
power client 17
channel 2462
station-role root
world-mode dot11d country SA both
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface Vlan111
no ip address
bridge-group 111
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
interface BVI111
ip address 192.168.111.1 255.255.255.0
ip access-group 104 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 1 permit 192.168.111.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 192.168.111.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip 192.168.111.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip 192.168.111.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark auto generated by SDM firewall configuration##NO_ACES_16##
access-list 105 remark SDM_ACL Category=1
access-list 105 permit ip any host 173.195.0.53
access-list 105 permit ip 10.1.10.0 0.0.0.3 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
access-list 105 permit ip 192.168.111.0 0.0.0.255 any
access-list 105 permit udp any eq bootps any eq bootpc
access-list 105 permit udp host 192.168.1.100 eq domain any
access-list 105 permit udp host 62.215.6.51 eq domain any
access-list 105 permit icmp any any echo-reply
access-list 105 permit icmp any any time-exceeded
access-list 105 permit icmp any any unreachable
access-list 105 permit ip 10.0.0.0 0.255.255.255 any
access-list 105 permit ip 172.16.0.0 0.15.255.255 any
access-list 105 permit ip 192.168.0.0 0.0.255.255 any
access-list 105 permit ip 127.0.0.0 0.255.255.255 any
access-list 105 permit ip host 255.255.255.255 any
access-list 105 permit ip any any
access-list 106 remark 106
access-list 106 remark SDM_ACL Category=64
access-list 106 permit ip any host 173.195.0.53
snmp-server community public RO
tftp-server flash:/phones/6901_6911/SCCP6911.9-1-1-0.loads alias SCCP6911.9-1-1-0.loads
tftp-server flash:/phones/6901_6911/SCCP6901.9-1-1-0.loads alias SCCP6901.9-1-1-0.loads
tftp-server flash:/phones/6901_6911/KNL6911SCCP.9-1-1-0.zz.sgn alias KNL6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/KNL6901SCCP.9-1-1-0.zz.sgn alias KNL6901SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/BFS6911SCCP.9-1-1-0.zz.sgn alias BFS6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/APP6911SCCP.9-1-1-0.zz.sgn alias APP6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/APP6901SCCP.9-1-1-0.zz.sgn alias APP6901SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/69xx/SCCP69xx.9-1-1-2-sr.loads alias SCCP69xx.9-1-1-2-sr.loads
tftp-server flash:/phones/69xx/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:/phones/69xx/DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:/phones/69xx/SCCP69xx.9-1-1-2-sr.zz.sgn alias SCCP69xx.9-1-1-2-sr.zz.sgn
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-9c.bin alias spa525g-7-4-9c.bin
tftp-server flash:/phones/7945_7965/apps45.9-1-1TH1-16.sbn alias apps45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cnu45.9-1-1TH1-16.sbn alias cnu45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.9-1-1TH1-16.sbn alias cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/dsp45.9-1-1TH1-16.sbn alias dsp45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.9-1-1TH1-16.sbn alias jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/SCCP45.9-1-1SR1S.loads alias SCCP45.9-1-1SR1S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/8961/dkern8961.100609R2-9-2-2.sebn alias dkern8961.100609R2-9-2-2.sebn
tftp-server flash:/phones/8961/kern8961.9-2-2.sebn alias kern8961.9-2-2.sebn
tftp-server flash:/phones/8961/rootfs8961.9-2-2.sebn alias rootfs8961.9-2-2.sebn
tftp-server flash:/phones/8961/sboot8961.031610R1-9-2-2.sebn alias sboot8961.031610R1-9-2-2.sebn
tftp-server flash:/phones/8961/sip8961.9-2-2.loads alias sip8961.9-2-2.loads
tftp-server flash:/phones/8961/skern8961.022809R2-9-2-2.sebn alias skern8961.022809R2-9-2-2.sebn
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 100 route ip
bridge 111 protocol ieee
bridge 111 route ip
voice-port 0/0/0
cptone KW
caller-id enable
voice-port 0/0/1
cptone KW
caller-id enable
voice-port 0/0/2
cptone KW
caller-id enable
voice-port 0/0/3
cptone KW
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
echo-cancel coverage 64
cptone KW
connection plar opx 32
description Configured by CCA 4 FXO-0/1/0-Custom-BG-OP
caller-id enable
voice-port 0/1/1
cptone KW
description Configured by CCA 4 FXO-0/1/1-Custom-BG-OP
caller-id enable
voice-port 0/1/2
cptone KW
description Configured by CCA 4FXO-0/1/2-Custom-BG-OP
caller-id enable
voice-port 0/1/3
cptone KW
connection plar opx 3A13
description Configured by CCA 4 FXO-0/1/3-Custom-CO3
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 32
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*Argentina*Long Distance**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2569].......
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*Argentina*Intertern 918.....
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*Argentina*Emergency**
preference 5
destination-pattern 9112
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
no dial-peer outbound status-check pots
gateway
timer receive-rtp 1200
sip-ua
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Mishaal Abdulaziz Al-Rayes
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 7945 SCCP45.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-9c
load 525G2 spa525g-7-4-9c
load 6921 SCCP69xx.9-1-1-2-sr
load 6941 SCCP69xx.9-1-1-2-sr
load 6961 SCCP69xx.9-1-1-2-sr
load 6901 SCCP6901.9-1-1-0
load 6911 SCCP6911.9-1-1-0
time-zone 31
date-format dd-mm-yy
keepalive 30 auxiliary 4
voicemail 32
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$rS2H$ItRW0sAAG8uXvohpf8EOW0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Aug 25 2012 13:38:35
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
service phone displayOnTime 09:00
service phone displayOnDuration 00:01
service phone displayIdleTimeout 00:01
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  277  dual-line
ring feature
number 15 no-reg primary
label Basement Living (1)
name Basement Living (1)
ephone-dn  278  dual-line
ring feature
number 24 no-reg primary
label Laundry
name Laundry
ephone-dn  279  dual-line
ring feature
number 23 no-reg primary
label Ladies Room (2)
name Ladies Room  (2)
ephone-dn  280  dual-line
ring feature
number 22 no-reg primary
label Ladies Room (1)
name Ladies Room (1)
ephone-dn  281  dual-line
ring feature
number 21 no-reg primary
label GYM
name GYM
ephone-dn  282  dual-line
ring feature
number 20 no-reg primary
label Main Kitchen
name Main Kitchen
ephone-dn  283  dual-line
ring feature
number 19 no-reg primary
label Driver Room
name Driver Room
ephone-dn  284  dual-line
ring feature
number 18 no-reg primary
label Cook Room
name Cook Room
ephone-dn  285  dual-line
ring feature
number 17 no-reg primary
label Basement Kitchen
name Basement Kitchen
ephone-dn  286  dual-line
ring feature
number 16 no-reg primary
label Basement Living (2)
name Basement Living (2)
ephone-dn  287  dual-line
ring feature
number 14 no-reg primary
label Basement Dinning
name Basement Dinning
ephone-dn  288  octo-line
ring feature
number 13 no-reg primary
label Diwaniya
name Diwaniya
ephone-dn  289  octo-line
ring feature
number 11 no-reg primary
label GF Living Room
name GF Living
ephone-dn  290  dual-line
ring feature
number 10 no-reg primary
label Office
name Office
ephone-dn  291  dual-line
ring feature
number 08 no-reg primary
label Playing Room
name Playing Room
ephone-dn  292  dual-line
ring feature
number 07 no-reg primary
label Abdulla & Abdulaziz Room
name Abdulla & Abdulaziz Room
ephone-dn  293  dual-line
ring feature
number 06 no-reg primary
label Ghada Room
name Ghada Room
ephone-dn  294  dual-line
ring feature
number 05 no-reg primary
label FF Kitchen
name FF Kitchen
ephone-dn  295  octo-line
ring feature
number 04 no-reg primary
label FF Living Room
name FF Living
ephone-dn  296  dual-line
ring feature
number 03 no-reg primary
label Baby Room
name Baby Room
ephone-dn  297  octo-line
ring feature
number 09 no-reg primary
label Reception
name Reception
ephone-dn  298  octo-line
ring feature
number 01 no-reg primary
label Master Bedroom Mdm.Dalal
name Master Bedroom Mdm.Dalal
ephone-dn  299
number A801.. no-reg primary
mwi off
ephone-dn  300
number A800.. no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 7081.053D.ABE7
ephone-template 16
max-calls-per-button 2
username "BLF" password 123456
type 504G
button  1f277
ephone  5
mac-address 68BC.0C81.F630
ephone-template 16
username "RC" password 123456
type 7945
button  1f297
ephone  6
mac-address 68BC.0C80.3712
ephone-template 16
username "MK" password 123456
type 6901
button  1:282
ephone  7
mac-address 64A0.E714.D38C
ephone-template 16
username "FK" password 123456
type 6901
button  1:294
ephone  8
mac-address 64A0.E714.D33E
ephone-template 16
username "GY" password 123456
type 6901
button  1:281
ephone  9
mac-address 64A0.E715.D854
ephone-template 16
username "BK" password 123456
type 6901
button  1:285
ephone  10
mac-address 64A0.E715.D7B4
ephone-template 16
username "LK" password 123456
type 6901
button  1:278
ephone  11
mac-address 68BC.0C81.F264
ephone-template 16
username "fl" password 123456
type 7945
button  1:295
ephone  12
mac-address 64A0.E715.124B
ephone-template 16
username "DS" password 123456
type 7945
missed-calls all
button  1:288
ephone  13
mac-address 68BC.0C81.F195
ephone-template 16
username "GLF" password 123456
type 7945
missed-calls all
button  1:289
ephone  14
mac-address 68BC.0C81.F43D
ephone-template 16
username "mr" password 123456
type 7945
missed-calls all
button  1:298
ephone  15
mac-address 7081.053D.AB18
ephone-template 16
username "OG" password 123456
type 504G
button  1:290
ephone  16
mac-address 7081.053D.AC6A
ephone-template 16
username "ar" password 123456
type 504G
missed-calls all
button  1:292
ephone  17
mac-address 7081.053D.AB0C
ephone-template 16
username "GR" password 123456
type 504G
missed-calls all
button  1:293
ephone  18
mac-address 30E4.DB80.B3C8
ephone-template 16
username "LRD" password 123456
type 502G
missed-calls all
button  1:279
ephone  19
mac-address 7081.053D.ABAE
ephone-template 16
username "PR" password 123456
type 504G
button  1:291
ephone  20
mac-address 7081.053D.91C8
ephone-template 16
username "bd" password 123456
type 504G
button  1:287
ephone  21
mac-address 7081.053D.ABCA
ephone-template 16
username "bl" password 123456
type 504G
button  1:286
ephone  22
mac-address 7081.053D.AC2E
ephone-template 16
username "br" password 123456
type 504G
missed-calls all
button  1:296
ephone  23
mac-address 30E4.DB80.B49C
ephone-template 16
username "LR" password 123456
type 502G
missed-calls all
button  1:280
ephone  24
mac-address 30E4.DB80.B3C1
ephone-template 16
username "CR" password 123456
type 502G
button  1:284
ephone  25
mac-address 30E4.DB80.B4A7
ephone-template 16
username "Dr" password 123456
type 502G
button  1:283
Any Help ?
thanks and regards
guangfu_chen
not:
please bind the interface for ip was 10.1.1.1
Hello follow an example of Jabber config on the System Admin guide, please read the section to how configure a Cisco Jabber on CME:
Configuring Cisco Jabber: Example
The following example shows phone type Cisco Jabber configured under voice register pool 10:
voice register dn  10
number 1089
call-forward b2bua busy 1500
call-forward b2bua mailbox 1500
call-forward b2bua noan 1500 timeout 20
pickup-call any-group
pickup-group 1
name CME SIP iPhone
label CME SIP iPhone
voice register pool  8
park reservation-group 1
number 1 dn 10
dtmf-relay rtp-nte
ephone-dn  61
number 1061
park-slot reservation-group 1 timeout 10 limit 2 recall retry 2 limit 2
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1060498
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
