03-26-2020 11:41 PM
Hello experts,
Can someone tell me, which way RTP traffic will take for 2 external Jabber user.
So Callflow will be: external Jabber User A --> Expressway E --> Expressway C --> CUCM --> Expressway C --> Expressway E --> external Jabber User B
So if the call is established, which way will RTP traffic between Jabber User A and Jabber User B will take? Directly between A and B or via Expressway C?
ON CUCM I don´t use "Media termination point required", so I shouldn´t go via CUCM at all.
Need help!
Solved! Go to Solution.
07-01-2020 05:18 AM
Direct media in MRA is only possible with ICE media pasthrough. For this to work the jabber clients will need to have IP connectivity with each other using either their host up address or their NAT public IP. As long as you can guarantee that this is the case then you can have direct media between the end points.
NB: IF there is no IP connectivity between them then media will be anchored on the expressway servers.
There are a few requirements for ICE media pasthrough to work...
1. You need CUCM/IMP/Expressway 12.5, Jabber 12.5 and above
1. Enable OAuth
2. Enable SIP OAuth
3. Enabled mixed mode, CAPF and configure physical phones to download LSCs
You can refer to the documentation here
03-27-2020 02:55 AM - edited 10-20-2020 06:39 AM
The answer to this is it depends. There are a number of things that comes to mind.
07-01-2020 02:45 AM
We plan to deploy 2000 users in MRA environnement during at least one year.
All the applications will be hosted in our DC.
We already made a POC with expressway C-E in a classic mode.
Do you have a white paper to describe the best way to deploy ?
We would like to have a direct RTP between remote Jabbers and phones
Can you guide us ?
Philippe CUVILLIER cell +33 688094567
07-01-2020 05:18 AM
1. Enable OAuth
2. Enable SIP OAuth
