Jabber Phone Only Mode - Video Calls ?`
Hi Guys,
I got to get two iPhone Jabber clients get registered to CUCM 8.6. Was able to make calls. But Video calls does not seems to be working. I have enabled Video options and region settings. what else is needed.
Check that "Media Termination Point Required" is unchecked on device page , also MTP is not being inserted into the call. If the issue persists you can get detailed callmanager service traces to check SDP part of SIP signaling to see what is happening in video negotiation.
Manish
Manish Gogna
Please confirm that "Video Capabilities" is enabled on the TCT device in CM, it is disabled by default.  Also video is only supported on the 4s and later models of iPhone. Confirm other settings as per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/iPhone/9_5/JABI_BK_J38B2ACB_00_jabber-iphone-server-setup-9-5/JABI_BK_J38B2ACB_00_jabber-iphone-server-setup-9-5_chapter_0101.html
Manish
Thank you for taking time in supporting..
I have already tried enabled Video Capabilities on both iphones. iphones are 5s and 6.
i dont think i need the cop file anymore..
Region settings also checked..
What else could be wrong? or miss configured?
Manish
thanks.. that did the trick..
