Jabber / Presence Setup
david.sickle
Recently upgraded to CUCM 9.1 and I'm new to Presence and Jabber.  From what I can tell most of the configuration is done on the Call Manager side now but I'm still confused whether I need a standalone CUPS server and how to tell if I can actually set it up on my system.  Can anyone provide suggestions?  Thank you in advance.  CUCM version:
CUCM 9.1.1.20000-5
2 Accepted Solutions
Chris Deren
All the user provisioning was moved under CUCM, the IMP server (CUPS) is still the presence engine and is required.
HTH,
Chris
Jaime Valencia
You still build the basic integration as before, you should start by reviewing the IM&P documentation:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_installation_and_configuration_guides_list.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Chris Deren
HTH,
Chris
Jaime Valencia
java
java
