jabber share screen mobile and remote access grayed out
Anas Abueideh
Level 9
Level 9
Dear Experts,
We are deploying Mobile and remote access in the below topology
We are are using desktop sharing feature inside the network without any issue.
Our issue is related to the users login using MRA feature. the sharescreen option is greyed out.
when we have user logging from outside with user logging from internal network, the outside user has share screen button greyed out. for the internal user, the button is working.
when the internal user press the share screen button, it is not reaching the outside user.
kindly advise how to solve this issue.
thanks in advance
Anas
Manish Gogna
Hi Anas,
What are the jabber and Expressway versions in use? Please check the following bug
https://tools.cisco.com/bugsearch/bug/CSCuu22458/?reffering_site=dumpcr
Document screen sharing limitation for Jabber over MRA
CSCuu22458
Description
Symptom:
Screen Sharing option will be grayed out in Jabber when connected over MRA. This is believed to be a product limitation with MRA at the time of this filing and the bug is filed to document the limitation.
Based on the chart here, it appears receive screen share will work:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_6/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and-installation-guide/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and_chapter_01101.html
This bug is to more clearly have the limitation documented, especially in the release notes.
Conditions:
Connected over MRA
Workaround:
None known at this time.
Manish
Hi Manish,
Thanks for your reply.
Expressway version is 8.6.2.
I want to ask you also about file transfer with MRA, it is greyed out also. do you know why ? is it the same like share screen ?
Anas
Hi Anas,
As per the MRA deployment guide ( page 28 ) , it is an unsupported feature
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-1-1.pdf
Manish
