12-09-2016 03:05 AM - edited 03-17-2019 08:54 AM
I have just encountered something weird on our jabber deployment and was wandering if someone had seen a similar issue.
The jabber devices seem to be ignoring the Device level CSS.For example if I don't place a CSS on the line but have a correct and working CSS on the device level I can't place any calls.
This only fails for TCT and BOT devices, CSF seem fine.I've had a look through the bug tool and can't find anything obvious ( We're running CUCM 10.5(2)SU3)
Solved! Go to Solution.
12-10-2016 10:32 AM
See if device mobility is kicking in and perhaps putting you in roaming device pool.
12-10-2016 10:32 AM
12-15-2016 06:43 AM
Nail on the head , thanks
