Webcast SD-WAN
150
Highlighted
Beginner
Jabber Transfer call steps/process experience oddity
Hi all,
We've just gone live with an all Jabber softphone environment and we have an odd call transfer experience -
1. External caller calls in
2. Call is answered in Jabber by Agent A
3. Caller needs to be transferred to Agent B
4. Agent A clicks on the three dots and selects transfer
  At this stage, the external caller is not put on hold and can hear agent A typing in agent B's name
Once Agent A has typed in typed in the name and pressed enter, the caller is finally put on hold.
Is this normal behavior? we would expect that the external caller is put on hold as soon as Agent A selects transfer, therefore they don't hear the keystrokes when agent A is typing in Agent B's name.
Thanks in advance.
1 ACCEPTED SOLUTION
Enthusiast
Re: Jabber Transfer call steps/process experience oddity
It seems that you are hitting a software bug CSCus09463:
Symptom:
When we transfer a call on Jabber, we select transfer, then type the number.
At this condition, the person on the phone can hear our voice while typing the number.
That is, a call is not hold and MoH does not flow.
Conditions:
Jabber for Windows
Jabber for MAC
Workaround:
None
Further Problem Description:
None
Check below post as well:
https://community.cisco.com/t5/cisco-bug-discussions/cscus09463-jabber-for-windows-mac-should-hold-the-call-when-we/td-p/3349459
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
4 REPLIES 4
Enthusiast
Symptom:
Conditions:
Jabber for Windows
Jabber for MAC
Workaround:
None
None
This is a known bug, can you specify you CUCM version and the Jabber software version that you use?
Have you tried to upgrade your Jabber software version to a newer release?
G
Please always Rate Helpful Posts and/or Mark Solutions as Accepted
Beginner
Thanks George, CUCM is 12.5.1.10000-22 and Jabber is 12.5.1.27406-22. I'll update to Jabber 12.6 and see what new :)
Look forward for your feedback
G
Content for Community-Ad
June's Community Spotlight Awards
