JTAPI redundancy.
Ritesh Desai
Hi folks,
May be this is stupid question. Customer has VERINT as call recording solution. VERINT is configured with JTAPI user pointing to Publisher. In case, if Publisher goes down then CTI communication breaks and call recording stops.
Is there a way to achieve load balancing / failover logic in JTAPI.
If JTAPI Primary link with Publisher goes down, Secondary link with CCM Subscriber2 comes up.
Please suggest.
regards,
Ritesh Desai.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Dennis Mink
maybe try dns names instead of IP addresses if Verint lets you. and build redundancy into the hostname itself.
Please remember to rate useful posts, by clicking on the stars below.
