04-05-2016 02:50 PM - edited 03-17-2019 06:28 AM
Good day!!!
One question I have one phone CP 8851 with one module 8800, the phone recognize the module and in the Phone configuration already enable in Expansion Information.
the question is how I can add speed dials in the module 8800, the speed dial only can add to phone.
Solved! Go to Solution.
04-26-2016 11:59 AM
Have you applied the template to user profile( if using Ext Mobility) or to the phone .
Do you see add on module on the phone page and line appearance on it
04-05-2016 03:12 PM
Have you adjusted the phone button template as required??
04-26-2016 07:47 AM
Phone Button template is 8851 SIP ??
Exist any guide to configure ??
04-26-2016 07:58 AM
Just copy the standard 8851 SIP template and then configure the lines and speed dials
as per below screenshot .it allows you to configure 77 L or SD
04-26-2016 08:23 AM
Yes I configured this, but don´t appers the speed dial in the module, the screen is only in blue.
04-26-2016 11:23 AM
Hi Christian,
The KEM screen is lit up blue means, it doesn't have any buttons configured with speed dials yet. The screen capture you have posted doesn't show much though, configure from button 11 to see first speed dial on your expansion module (of course, you configure a valid phone button template first).
Sami
04-26-2016 11:47 AM
I configured the first 25 speed dial but don´t work the screen continue in blue
In the line is necesary permit anything ? or in phone ?
04-26-2016 11:59 AM
04-26-2016 10:38 AM
It´s necesary install to firmware in CUCM ??
How I check if the module 8800 is compatible ??
04-26-2016 12:41 PM
Thanks you friend, now work :D
