lacale settings in CM 8.x
eicc30000
how do you change the language on the ccmadmin
web page.
thanks
Glen
5 Replies 5
phooghen
You must first download the specific country locale from CCO and upload to any node of your cluster.
Here are a few links:
For information about Locale Installation:
(1) Go to this URL : http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
(2) Locate the appropriate release of Cisco Unified Communications Manager and select "Cisco Unified Communications Operating System Administration Guide."
For information about User Locales for the Tool for Auto-Registered Phone Support (TAPS):
(2) Locate the appropriate release of Cisco Unified Communications Manager and select "Cisco Unified Communications Manager Bulk Administration Guide."
For information about Cisco Unified Communciations Manager Administration:
(2) Locate the appropriate release of Cisco Unified Communications Manager and select "Cisco Unified Communications Manager Administration Guide."
For roundtable phones User Guide download:
http://www.cisco.com/en/US/products/ps10453/tsd_products_support_translated_end_user_guides_list.html
For rt-lite phones User Guide download:
http://www.cisco.com/en/US/products/ps10326/tsd_products_support_translated_end_user_guides_list.html
thanks phooghen
i have the locale installed, i need to switch to it on the CCMAdmin, is it on the OS administration or enterprise parameters ??? i looked but coudlnt find where
If you want to enable it on all the phone, do it at the "Enterprise parameters" > "Localization parameters" :
Default network locale + default user locale
This requires a reset of all the devices to take effect.
Pierre.
would this affect the administration page without affecting the phones ?
In order to apply the new enterprise parametres, you will have to reset all the phones.
Pierre.
