Community Helping Community
345
Highlighted
Participant
Large Scale Analog phones on CUCM 8.6
                   Hello everyone,
the need is for about 500 analog phones connecting back to to CUCM 8.6.  Does anyone have a way to get that many analog phones over to CM using something other (read cheaper) than VG224s?
Thanks in advance!  All replies rated.
1 ACCEPTED SOLUTION
Hall of Fame Master
New VG350 GW is the other option:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/data_sheet_c78-710996.html
though I have not done cost comparison, if you do one, make sure you consider annual smartnet support as well, power consumption, etc.
HTH,
Chris
1 REPLY 1
Hall of Fame Master
HTH,
Chris
Content for Community-Ad
FusionCharts will render here
