03-24-2010 11:26 AM - edited 03-15-2019 09:56 PM
Platform - CUCM 7.1.3
After logging into Serviceability and clicking on CDR Analysis and Reporting I get the popup page that shows the number of records in the CAR database and I also see this error message: "Last run of CAR Loader is unsuccessful, please check the CAR Scheduler Logs for more information."
I'm not sure where to find the CAR scheduler logs to debug this error. Can someone be of assistance?
One other thing that I have noticed when running Route and Line Group Utilization reports....in the previous version of CCM I was running (4.2.3), I could run a trunk utilization report for an entire week based on hour of day and the report would show me the busy hour for each day of the week. Now when I run that same report in 7.1, it averages the daily busy hour. To get the actual busy hour for each day, I now have to run a separate report for each day of the week which takes a lot more time. The only thing that is different configuration wise is that in the new version I am doing 24/7 loading of CDRs instead of once every 24 hours as in my previous version. Could this cause the change in reporting? Thanks!
Brett
Solved! Go to Solution.
02-09-2011 09:47 AM
It looks like you are hitting the following defect.
CSCsy90529 CDR Load status shows Unsuccessful if it is interrupted by DRS backup
08-25-2010 10:15 AM
Did you ever get anywhere with this? I'm getting the same error and all the logs I look at are giving my very general "CAR Load was unsuccessfuly'. I'm assuming a TAC case will be needed, but I always like to avoid that at all costs.
08-25-2010 01:12 PM
No the issue cleared itself when I changed the loading of CAR records from constant to every 24 hours. I have since changed it back and the problem appeared again. If you open a TAC case and they resolve the issue, please post the solution. Thanks!
Brett
02-09-2011 09:47 AM
02-09-2011 11:23 AM
Yep that's it. Excellent detective work Jason - 5 stars. I confirmed the errors in the trace logs collected from RTMT. I figured it was cosmetic as all of my CAR data appears to be consistent, but it's good to have it confirmed. Thanks!
Brett
09-26-2011 12:35 AM
Guys,
so what I have to do to run CAR Loader successfully? I restarted all services but still got this erros.
I can`t open Jason`s link due to low priviledge rights.
@ bsugamele1 Have You resolved this issue ? Please, help
CUCM 7.1.5
09-26-2011 12:55 AM
Hello!
Currently is CDR giving you the correct data?are you able to run the reports?
If the question is how to get rid of the error mentionted in the hread earlier, then the error occurs because the CAR services get restarted during the backup, causing the warning, this does not effect your CDR processing/production..
Its more like an expected error, if i understand your question correctly!
Hope this makes sense
Kunal
09-26-2011 02:22 AM
Yes, I am able to run reports (users, gateways...) Seems like it is working fine even if we have this error.
I used to think that this "expected error" somehow influences on system production \ reports....
thanks for answer
09-26-2011 02:50 AM
One more question about e-mail reports
I get this error when trying to mail report
Error Code
10011
Error Description
System Error. Contact System Administrator.
there is no authentication on our SMTP mail server.
Mail Id - any (example YourName)
pass - no
domain - name - (example abc.com)
Mail Server Name - here I give IP address of Mail server
What is wrong ? Do your use e-mail reports ?
This advise did not help - http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080933fcf.shtml
09-26-2011 07:12 AM
I do not get this error message anymore, but I also did not do anything to resolve it. One day it magically quit displaying that error. Sorry I couldn't be of more help there.
As far as the mail configuration goes....make sure CARAdmin is a valid user account on your exchange server and make sure the password is correctly configured in CUCM servicability. I have the FQDN of my exchange server set in the mail server name field.
-Brett
06-11-2013 05:54 AM
I have the same problem at our CUCM 8.6.2 ->
When I try to open the links to the bug toolkit I get the message -> "Your Cisco Guest Login is not entitled to use Bug Toolkit. "
Can anybody help me to solve this problem? Thanks.
By the way: Could it be because of this error that CDR data out of RTMT are different to data from SQL to tbl_billing_data?
BR
Michael
06-11-2013 07:00 AM
Hi Michael,
Here are the bug notes;
Apr 18,2013
Assigned (A)
4 Minor
Cisco Unified Communications Manager (CallManager)
82
Known Affected Releases: | (1 |
"go easy...step lightly...stay free "
- The Clash
06-12-2013 12:31 AM
Hi Rob,
many thanks. Then I will have a look at the daily backup of CUCM that runs at 0:05 am and change this to another time.
Is it possible to schedule saving CDR from -> Serviceability -> CDR Analysis and Reporting so that CDR automatically will be saved to a specified path every day?
Another question is why I see in CDR from -> Serviceability -> CDR Analysis and Reporting a lot of entries with duration "0"? Such entries I don`t have when I make SQL query to CAR from CLI.
What does it mean a entry with duration "0"?
BR
Michael
06-12-2013 10:48 PM
Hi Rob,
I still have the error "Last run of CAR Loader is unsuccessful, please check the CAR Scheduler Logs for more information."
The CDR Load schedule is set to "Countinous Loading 24/7".
In system -> Log screens -> event log -> CDR Load I only see status "unsuccessful".
Where can I find the mentioned "CAR Scheduler Logs" to see what the problem is?
BR
Michael
10-04-2019 04:08 AM
If you are running your CDR load 24/7, you are always going to crash into your DRS backup yes/no?
Try re-scheduling the load for a specific time well away from your DRS backups and see if the problem clears.
All the best
