LDAP and multiple Access Control Group
prantikdg1383
Hi All,
I was wondering if there is any way for the following scenario:
we have multiple teams with different access group requirements, now when using LDAP is this possible?
we can definitely do that by creating different LDAP Directories but then we would need to create a lot of groups on LDAP.
any way doing it with a single LDAP directory and one group in LDAP?
Prantik
Philip D'Ath
What sort of Cisco device is this?
This is a CUCM 10.0 and AD integration.
Jaime Valencia
If you mean the Access Control Group when you define when configuring the sync agreement, no, those are PER LDAP sync agreement.
If you only want one sync agreement, you'll have to manually adjust the control groups for the users.
java
if this helps, please rate
