05-26-2009 10:38 AM - edited 03-15-2019 06:12 PM
It is suggested that the entire set of users defined in the LDAP directory is not imported into Unified CM cluster.
Because of our existing AD-structure, we will not be able to control the account export and for instance, omit OUs and none-IP-phone users from the directory synchronization via AD.
What are some of the control mechanisms to limit the number of use accounts imported, regardless of the LDAP database size?
05-26-2009 12:30 PM
You can re-organize your OUs to make it work correctly with CUCM. Basically, CUCM can sync up to 6 OUs I believe (top level, sub levels, does not matter)
Your other option is to find a third party LDAP tool to pull your AD accounts/passwords to a "merged" LDAP directory that CUCM can then sync with.
For service accounts, you can add in the Tildi ~ symbol in front of the first name and/or last name and CUCM will ignore this account and not sync it.
05-26-2009 01:54 PM
I use the LDAP Filter on the IPPhone Field in AD described breifly in the post below. Of course it is not supported by Cisco but works great.
