08-13-2013 06:30 PM - edited 03-16-2019 06:50 PM
I have created a new user in AD and force LDAP sync, when I go to User managment on CUCM and End user I can't find the new user.
COuld someone please help. Thanks
08-14-2013 10:56 AM
Wrong forum, post in "voice - IP Telephony". You can move your post using the actions panel on the right.
08-14-2013 10:01 PM
Is the user in the right OU??
Does it have a surname??
If you have filters, does it match them??
08-14-2013 10:12 PM
yes the user in the right OU and they have a surname. what do you mean about If you have filters, does it match them?
What happened is I have forces the LDAP sync from the LDAP Directory for first time and then stopped syncing. I have changed the time before I force the LDAP Sync and saved the changed because every time I force the ldap sync i get
"Can't Schedule Next Resync In The Past". thanks
08-14-2013 11:23 PM
That is not very useful, doing a once off forced sync!
So please be a bit more clear about your issue. Is it that you can't do a sync schedule because of the "Can't Schedule Next Resync In The Past".-notification message,
or cant you do a forced sync anymore, period?
Please remember to rate useful posts, by clicking on the stars below.
08-14-2013 11:29 PM
I can't do "force sync because of Can't Schedule Next Resync In The Past" also I can't do a sync schedule. thanks
01-18-2015 11:06 PM
I had this problem but mine was very silly (I was very silly),
please check the sync schedule, and make sure the date is not past, mine was set to 7 days ago which is very stupid to schedule a sync process for a date that is already passed.
