01-26-2012 02:22 AM - edited 03-16-2019 09:13 AM
I have a test CUCM 6.1 and Microsoft AD set up on VMWare.
I have taken a back up of our live CM and installed this into the test database as well as taken a live back up of our AD and installed this on the test Server.
CM currently has 2039 users and AD has over 4000 users. I want to integrate AD with CM. I have created an account in AD with Domain Admin rights. When I perform the sysnc all the 2039 users are there and are active, However the users in AD did not create in CM and the users I have in CM that I do not have in AD have also been synced.
Any assistance is appreciated.
01-26-2012 06:37 AM
Are all the users in the container (i.e. OU) you are using as Search Base? Did you start Dirsync service?
Chris
01-26-2012 07:08 AM
Hi Chris
Thnak for the reply. All the users are in the same OU.
The DirSync service boxed is ticked.
Jay
01-26-2012 07:13 AM
Are you sure all 4000 users are defined as users and not other accounts?
Chris
01-26-2012 01:58 PM
Hi Jayesh
Maybe post up some more screen grabs - your sync config from CUCM showing search base, and the OU structure in AD Users & Computers showing the location of the user accounts...
Aaron
01-26-2012 07:13 PM
You dindnt define an ldap filter in cucm, that prevents the other 1900 users from
Being populated into cucm by any chance?
01-30-2012 02:31 AM
Thanks for the reply minkdennis.
Under system, LDAP, I have LDAP System, LDAP Directory and LDAP Authentication options avilable. I don't have LDAP filter.
Is there anyway I can access this
Jay
01-30-2012 07:34 AM
Access what?
LDAP filter was not available in your version via GUI, if I recall correctly it was only definable via CLI. So, if you did not define it there is no filter.
Chris
01-27-2012 08:25 AM
01-30-2012 02:54 PM
Hi Jayesh
Firstly - the default LDAP filter for AD is : (&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2)))
So custom LDAP filters replace this, and you should use this as a basis, e.g. to filter out users that have no first name: (&(&(objectclass=user)(givenName=*))(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2)))
In your case, I think you have your agreement set up wrong. Your domain DN is :
dc=netlincs,dc=gov,dc=uk
f you wanted to just search the Netlincs/Netlincs User OU, your search base should be:
ou=netlincs users,ou=netlincs,dc=netlincs,dc=gov,dc=uk
Some contains (e.g. users or builtin) are 'special', so would be containers rather than OUs:
cn=users,dc=netlincs,dc=gov,dc=uk
Geddit?
Principal Engineer at Logicalis UK
Please rate helpful posts...
