192
Highlighted
Beginner
LDAP synch issue
Hi!
Why is it  that the CUCM does not support IBM Domino Directory Services? Seems to strange that synchronising against a directory and retreive some fields could be so difficult? What are the options for a customer who has IBMs Domino, other than not buying the CUCM ;-)
What are the pitfalls of using the embedded CUCM UDS, a part from the obvious problem of having it continously maintained.
1 REPLY 1
Highlighted
Hall of Fame Master
This is more question for Cisco Business Unit than this forum, however my take on this is that there are less and less customers out there using Domino and Cisco's and everybody's guess is that eventually they will disappear.
In either case you can use the local UDS directory with the caveats of users mainteining seperate passwords for loging into CUCM end user pages for example, and everywhere else where password might be required (admin page).
HTH,
Chris
