LDAP Users are not Sychornizing CUCM 11.0.1.22900-14
HARIS_HUSSAIN
I have CUCM 11.0.1.22900-14 and AD 2012 R2.  Trying to setup the Synchronization between two. CUCM Is able to connect the LDAP Server but none of the user populates. Based on search on forums i have confirmed that last name is not empty in the AD and also all the fields listed in  AD ( Table 16-4 Synchronized LDAP Attributes and Corresponding Unified CM Field Names):
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/directry.html.
On further analyzing the packet capture  and logs what i see is that CUCM is sending the Request and no results are found.
18           2016-11-09 10:32:43.971702         192.168.10.15     172.24.155.65     LDAP     275         searchRequest(2) "ou=Trainee, ou=Users Accounts, dc=*****, dc=local" baseObject
19           2016-11-09 10:32:43.972095         172.24.155.65     192.168.10.15     LDAP     88           searchResDone(2) success  [0 results]
Tried Restarting Dir Service.
On Packet capture i can see below filter [Although I have not choosen any filter in the LDAP Directory page]
Any One here has any Ideas what is going on.
5 Replies 5
Ryan Huff
Level 4
Level 4
Have you verified the search base string is correct? I suggest using something like Apache's Directory Studio (free) and verify the search base string that CUCM is issuing to AD is correct.
Ryan
Jaime Valencia
There's always a default filter for any LDAP config, and that's what you're seeing.
Does the user you're using in the sync has read permissions over the OU(s) you're trying to sync?
java
if this helps, please rate
seanvaid
Level 3
Level 3
Lets run thru a quick couple things-
*Please omit sensitive information
Paste your LDAP Manager Distinguished Name field and LDAP User Search Base
Make sure password is correct
Are you using a filter? If so, show what it is
Do a screen capture of LDAP Directory Synchronization Schedule and Standard User Fields To Be Synchronized
I assume you're able to verify connectivity between the two? Maybe try a couple pings
What port number are you using? TLS?
Hostname or IP?
HARIS_HUSSAIN
Thanks everyone for the update.
I was struggling to resolve this issue , I installed test CUCM 10.5 and configured same LDAP Sync rule and it worked !! Which confirms that configuration on LDAP Side is working Fine.
Tried restarting Dir Syc service still no luck.
Finally i rebooted the server and It started working.
Also another issue where presence users will show Unassigned in IMP server although assigned in CUCM was resolved. Same issue is reported in below post.
 https://supportforums.cisco.com/discussion/11708161/cisco-ucm-im-and-presence-90-syncing-not-working
Not sure what was the root cause but seems like something on LDAP was not working fine
Haris
Did you change the port number for the IM&P fix prior to the reboot?
